Old Mar 31, 2015, 04:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Overview
Print Wikipost
INSTALLING kill switch tips on a 98 ek hatch dx
Old Apr 23, 2010 | 08:35 AM
EF9_TryMe's Avatar
Default INSTALLING kill switch tips on a 98 ek hatch dx
can you guys give me some pin pointers on where the best place would be to mount a killswitch ?
Old Apr 23, 2010 | 10:10 AM
ekb16's Avatar
Default Re: INSTALLING kill switch tips on a 98 ek hatch dx
some place only you know about and easy to get to
Old Apr 23, 2010 | 11:53 AM
EBTurbo's Avatar
install one of these. you can mount it remotely and activate it by a toggle switch placed where ever you want. you can even put a few toggle switches in series to throw them off. This is what we use on the racecars. different application but similar in principle.
http://www.alliedelec.com/search/pro...px?SKU=5761078
- EB Turbo
Old Apr 23, 2010 | 02:05 PM
EF9_TryMe's Avatar
i was just thinking about hooking mine up to the fuel pump wire that gets power once the ignition switch is on. would that work ?
Old Apr 23, 2010 | 02:14 PM
EBTurbo's Avatar
Not really. do you have a battery drain problem or a theft problem? the problem with doing it that was is you will not have battery power to even energize the fuel pump relay. the battery kill needs to be a separate key or switch. you can wire it up to the ignition switch but that wont be a theft deterrent system. only a battery drain fix.
- EB Turbo
Old Apr 23, 2010 | 02:56 PM
EF9_TryMe's Avatar
- EB Turbo
Why won't it work with just putting a switch in between the actual fuel pump itself[undearneath the seat, and the wire thats coming from the relay/harness.], and extending it to some place that i would like to get it installed somewhere where i would like. By using like an aftermarket switch or something. By the way, does that relay/switch come with installation device and how hard is it to wire it up ? Im using this for anti-theft features.
Old Apr 23, 2010 | 03:54 PM
EBTurbo's Avatar
I'm sorry, I was under the impression that you wanted to use the fuel pump wire to trigger the battery kill switch.
You can put a switch or preferably a relay in between the fuel pump wiring. that is a pretty easy task.
The battery kill I linked before is only used for batteries. It is quite larger then the picture seems. it works the same way as a solenoid or a relay. you will have to wire it up yourself. and it is really straight forward. the only downside is having to crimp lugs larger then 6awg.
- EB Turbo
Old Apr 23, 2010 | 08:36 PM
EF9_TryMe's Avatar
I see, yeah I'ma go a little bit easier on this and a little "ghettoer" but in the end it all works out. I really don't have 60 dollars to spend on that battery killswitch, but that is something amazing. Ive heard about race cars using those. Thanks for the info, definitely bookmarking that stuff when I become a true drag racer or something. ;]
Old Apr 24, 2010 | 06:15 PM
rick_rabies's Avatar
I'm not Rick!
battery/alt kill switch in the trunk(batry in the trunk)
fuel pump kill switch under driver seat.
ecu kill switch on the dash (unlabeled with other switches)
another power kill switch in glove box...........
pull fuses when not in use
mount lawn mower blades under car by the drivers door. when breaking in..SSSCHWWINNG.chop
remove steering wheel (release hub) and keep the wheel with you.
unplug dizzy or other things like starter or ecu (if to let sit for days or weeks)
ideas ideas ideas
Old May 14, 2010 | 03:39 PM
murdered sol's Avatar
I was thinking about putting a fuel pump cut off behind the fuel door
Old May 14, 2010 | 10:02 PM
xero_xero's Avatar
Read my sig, it is a step by step for the mos theft prevention aside fron removing the steering wheel.
Old Jun 27, 2010 | 12:25 PM
EF9_TryMe's Avatar
thanks for the tips guys, i'm trying to be as secure as possible when it comes to my honda.
boostedb20z
Mar 23, 2009 05:59 PM
underpressure02
Apr 23, 2007 08:42 AM
Turbo EH2
Apr 12, 2007 07:45 PM
SpoolinEK9
Audio / Security / Video
Jun 21, 2004 07:44 PM
flip1199
Jun 19, 2004 12:13 PM
