b20/vtec question
Old Apr 8, 2010 | 01:38 PM
perseverance's Avatar
Default b20/vtec question
question.... when you use the dowel pins that have two sizes, the one's they sell on ebay so you don't need to machine the head to accept the other pins, Do you have to do anything to the headgasket? do you still use the oem gasket?
Old Apr 8, 2010 | 03:21 PM
havok hybrid's Avatar
Default Re: b20/vtec question
those are LS vtec dowel pins.
DROP in and go.. Nothing needs to be done to the head or the block.
golden eagle makes them.
Old Apr 8, 2010 | 03:28 PM
i kno that you don't have to do anything to the head or block, other than thread the hole for the oil. i've built them before but i didn't use those pins. i'm wondering if you need to modify the headgasket to work with those pins or no.
Old Apr 8, 2010 | 03:57 PM
No modding of the gasket is needed
These pins.. allow the new vtec head to accepted.. big side of the plug enters the head when you bolt it to the block.
The small side of the pin fit into the OEM hole on the block. Leaving only the OEM dowel pin size to be used with the gasket..
Old Apr 8, 2010 | 04:01 PM
just the answer i was looking for thanks! reason i asked is on golden eagle's site it's saying that they're may be modification required for the headgasket but i didn't think so. thanks again!
XFactor27
Dec 31, 2011 10:44 AM
Chpwhtek
Dec 14, 2011 12:31 PM
95dc2teg
Dec 10, 2009 07:23 PM
ANNiHiLATORS
Nov 28, 2009 11:35 PM
blackcrx16
Feb 28, 2008 04:04 PM
