clutch pedel really soft?
Old Apr 23, 2010 | 12:23 PM
gretna24's Avatar
Default clutch pedel really soft?
today i test drove a 95 honda civic and the guy told me he had some one install a new clutch which is true cause i wanted to buy it a few weeks ago but the clutch was bad.well anyways the pedel felt really really really soft what could this be?could it be that because its a new clutch it needs to be broken in,slave cylinder is bad,or it needs to be bleeded?idk
also it was going in gear real smooth with no problems
Old Apr 23, 2010 | 02:45 PM
riceburner700's Avatar
Default Re: clutch pedel really soft?
could be one of three things, air in the system, leaking master cylinder or a slave on its way out
Old Apr 23, 2010 | 04:54 PM
Mutiny1's Avatar
i would try bleeding the slave as first step. bleed it a few times and then pump the hell outta the clutch for a few mins and if that dont seem to fix the problem then check for leaks in master and slave cylinders.
Old Apr 24, 2010 | 02:24 PM
gretna24's Avatar
ok well do i just wanted to make sure its not something serious
sibious
Jun 13, 2008 03:53 PM
94civicgsr
Dec 25, 2007 06:29 PM
Liquidgsr
Mar 31, 2007 12:14 PM
Greenery18
Jul 8, 2005 04:22 PM
DriveSideWays
Aug 27, 2004 05:06 PM
