Using a jack stand at its minimum height?
Old Apr 6, 2010 | 02:35 PM
fleabag's Avatar
Default Using a jack stand at its minimum height?
I read a story of a guy who thankfully did not die but who used some jack stands and one day the car came down. It turns out that the ratcheting mechanism on the paw for the jack stands broke at the part where it was holding up the adjustable "arm". So I was thinking that maybe I should just get jack stands that have a minimum height that I'm looking for..
These are 4 ton jack stands that start at 12 inches and go up to like 17 and 1/2 inches:
http://www.sears.com/shc/s/p_10153_1...d=12+ton+stand
These are 12 ton jack stands that START at 17 inches and go up to 27 inches.
So, instead of getting the jack stands that go UP to 17 inches, I'd instead get the jack stands that START at 17 inches and just use it at that height..
What do you guys think? Also has anyone ever used these taller jack stands to work on their civic? I figure that if I get tall enough jack stands, I won't have to remove the bumper in order to do an engine swap and whatnot because the car would be high enough to clear it.
Old Apr 6, 2010 | 03:02 PM
fatboy1185's Avatar
Big Cat
Default Re: Using a jack stand at its minimum height?
Buy a hydraulic lift for like 1 grand.
Old Apr 6, 2010 | 03:10 PM
Jenkinsal2's Avatar
Most likely the failing jackstand was a result of negligence or user error. Even so, when using a name brand set of jackstands I have never heard of a single problem. Get whichever of the two you want.
Old Apr 6, 2010 | 03:48 PM
fleabag's Avatar
thats what everyone assumed but I don't see how it can be negligence or user error. How can you even use these things improperly? I mean even if it isn't secure, it'll become secure soon as you put a significant load on it. he says that he was working on the car and then it failed. I've read a few reports of failing jack stands so I think it's definitely possible.
Old Apr 6, 2010 | 03:56 PM
Jenkinsal2's Avatar
One way is to use a set of jack stands not properly rated for the weight you are jacking up. You can also have them placed slightly off putting a load on the wrong section of the jack stand and create a force where their shouldn't be. I have seen way to many shifty movements with jacks and jack stands work out to believe that these products can fail. There are more idiots out there then shitty jack stands.
Old Apr 6, 2010 | 04:28 PM
fleabag's Avatar
speaking of putting loads on the wrong section of the jack stand, is it safe to have the arm resting on the base and having a load applied to it?
Old Apr 6, 2010 | 06:38 PM
rip94delsol's Avatar
We had one fail at the shop the other day, you can thank Matco for that one!
Old Apr 7, 2010 | 12:06 AM
Scott_Tucker's Avatar
I would not get the big stands. It is likely you could not lift your Honda high enough with a floor jack to mount it on them. I have a set of the smaller ones at my shop and they are plenty strong for any car.
zomart
Aug 6, 2003 02:27 PM
AcuraFiend
Jun 17, 2002 02:31 PM
subtleluck
Mar 19, 2002 09:59 PM
mr tl
Dec 22, 2001 03:14 AM
neumonik
Dec 16, 2001 02:51 PM
