Wont Shift !!!! please help
Old Apr 25, 2010 | 09:31 PM
millertime191's Avatar
Default Wont Shift !!!! please help
ok so i was driving and everything was fine i pulled up to the red light went to put it back in gear to go and it just wouldnt go in gear the clutch pedal is still there feels fine just when i go to put it in to gear its like there is no gears there non of the gears are there it moves like its there but no gears !?!?! maybe someone could shed some light the car is a 94 integra with a b18b1(ls) and trans is same cars pretty stock its my daily , please help if u can thanks !!
Old Apr 25, 2010 | 10:04 PM
Default Re: Wont Shift !!!! please help
anyone ? before i pull the motor and pull the trans off and see whats going on ?
Old Apr 25, 2010 | 10:36 PM
Old Apr 25, 2010 | 10:52 PM
Psychoteen101's Avatar
If the pedal feels good, id guess something happened with your clutch. Youll probably have to pull the trans and take a look inside.
Old Apr 25, 2010 | 11:41 PM
iam thinkin the samething^^^ , all the fluids are good the clutch *** presure just wont go into gear like wont move over to the right towards rev or nothing just kind of moves forward and back just no gears
Old Apr 26, 2010 | 09:57 AM
any help
Old Apr 26, 2010 | 09:58 AM
S2Integra's Avatar
check shift linkage bolt.
Old Apr 26, 2010 | 02:35 PM
there all tight its some inside just want to know if anyone has any idea whats goin on inside lol
Old Apr 26, 2010 | 05:59 PM
notfastenough's Avatar
Check the bushing for the counter bar. If you are saying the shifter moves through all the gates, but won't actually engage a gear, check the bushing on the second bar. With the car off, get under it and have someone put it into first gear. Watch for excessive movement in the stabilizing linkage. Also give the shifter linkage an extra push to try to engage the gear. Leave it like that, put the car on the ground and see if the gear engaged. If this doesn't work, plan on pulling the tranny. Good luck!
Old Apr 26, 2010 | 07:05 PM
all thats good its inside somehwere
Old Apr 26, 2010 | 07:11 PM
fotoguy's Avatar
Miller, will the shifter go into gear without power, (the car off, clutch not pushed in) Can you rock the car and get it into or out of gear?
Old Apr 26, 2010 | 07:29 PM
Also, I still don't understand if you are able to get the shifter into the normal positions for the gears. Are there any abnormal noises when trying to engage a gear?
Old Apr 26, 2010 | 08:52 PM
foto ^^ it no either with or without power its wierd as **** and cant rock it either into gear like theres no gears like the mexicans came up and took all my gears out my trans idk
Old Apr 26, 2010 | 08:53 PM
not fast ^^ the shift moves to where the gear is just no gear act its like gone like almost like the shift fork is in the trans
Old Apr 28, 2010 | 01:00 AM
kik
Old Apr 29, 2010 | 07:40 AM
SuBK's Avatar
Gotta be the clutch
Old Apr 29, 2010 | 12:05 PM
jdm602's Avatar
my money is on a bent shift gate. ive had that happen. fits exactly how he explains...
2fast4u_tegra
Dec 9, 2022 05:08 PM
millertime191
Apr 30, 2010 06:47 PM
millertime191
Transmission & Drivetrain
10
Apr 28, 2010 01:01 AM
eglude
20
Jul 1, 2009 09:43 AM
vietnamese0utlawz
Oct 5, 2006 08:38 AM
