getting code 7 on rebuilt b16a1 (pw0/pr3 ecu)
Old Jun 4, 2002 | 02:39 AM
mick's Avatar
Default getting code 7 on rebuilt b16a1 (pw0/pr3 ecu)
just rebuilt my b16a1, starts up ok (burning more oil than a bitch but it starts), but im running a code 7, which indicates TPS sensor.
anyone had any problems with the TPS sensor? likelyhood of it being a problem with the ecu or tps sensor? any comments much appreciated.
Old Jun 4, 2002 | 11:23 AM
mick's Avatar
Default Re: getting code 7 on rebuilt b16a1 (mick)
hm
Old Jun 4, 2002 | 01:14 PM
erniecars's Avatar
if its plugged and the wiring is in good shape the TPS could be crooked, especially if you ever removed it. You can loosen the 2 screws and turn it slightly. The washer make indentations so you may be able to see where it was before but if that thing is turned wrong you can get a cel.
Old Jun 4, 2002 | 02:32 PM
mick's Avatar
Default Re: getting code 7 on rebuilt b16a1 (erniecars)
i assume that even though it may not be set correctly but functional it won't give a code?
Old Jun 4, 2002 | 03:00 PM
Jared's Avatar
Do a voltage check and see if the TPS is even working. Any other codes? And btw, even with a fresh rebuild you shouldn't be burning oil so bad that it mosquito fogs.
Old Jun 4, 2002 | 03:03 PM
erniecars's Avatar
that is correct
Old Jun 4, 2002 | 06:08 PM
mick's Avatar
Default Re: getting code 7 on rebuilt b16a1 (Jared)
hrm - i shouldn't be burning alot of oil? (my spark plugs are black as f*ck) - what would be causing this?
Vette117
May 7, 2018 05:11 AM
REDREXMANB16
Nov 23, 2006 09:54 PM
jetblack
May 16, 2006 06:20 PM
NZcrx88
Aug 9, 2002 03:18 PM
.brad
Feb 26, 2002 03:30 AM
