differences in burning oil vs coolant
Old Jun 3, 2002 | 10:45 PM
Markaccord95's Avatar
Default differences in burning oil vs coolant
what are they, the ones you know...
Old Jun 3, 2002 | 10:50 PM
tinkerbell's Avatar
Default Re: differences in burning oil vs coolant (Markaccord95)
coolant doesn't burn,
it vaporizes.
t..
Old Jun 4, 2002 | 12:29 AM
kinesistech's Avatar
Default Re: differences in burning oil vs coolant (tinkerbell)
oil burns with a bluish/white color and coolant is WHITE. Too much fuel is brown.
Old Jun 4, 2002 | 12:59 AM
Kamin's Avatar
Default Re: differences in burning oil vs coolant (kinesistech)
too much fuel is brown or black. make sure you add the black.
and they each (oil and coolant) make a distinct smell. if your curious run your car for a while then drip some oil on the exhaust manifold (header/heat shield)
youll smell it.
Old Jun 4, 2002 | 01:08 AM
EG2's Avatar
EG2
Default Re: differences in burning oil vs coolant (KAMiN)
If I remember correctly while coolant will just take up space in the combustion chamber oil being burned will lower the knock resistance of the fuel.
Burning coolant is usually a result of a serious problem (blown headgasket, cracked waterpassage) while oil burnig problems are generaly easyer to fix.
Old Jun 4, 2002 | 01:13 AM
tinkerbell's Avatar
Default Re: differences in burning oil vs coolant (EG2)
um, how compressable is coolant?
do you know of hydrolock?
ANYTHING that takes up space in hte combustion chamber on a compression stroke that is not air/fuel will ususally create bent rods etc?
yes, oil vapours will -> higher chance of detonation...
Old Jun 4, 2002 | 05:54 AM
shion's Avatar
Coolant has a warm sweat sort of smell. Actually quite pleasant.
Old Jun 7, 2002 | 07:37 PM
Default Re: differences in burning oil vs coolant (shion)
i understand coolant and oil are both white.... but how do u determine which white is oil and which is coolant.
IE: my car puffs a little white after heavy acceleration, but there is no oil in the radiator, and its not using any abnormal amounts of oil (about 1/2 qt every 2000 miles)
Old Jun 8, 2002 | 12:51 AM
quickspoolin's Avatar
It also taste sweet . I found that out when I was under the car and some coolant dripped in my mouth, and boy was it sweet almost like koolaid. No wonder why dogs lick that stuff and die all the time.
oranginal
Mar 30, 2009 07:39 AM
IMHARD2
Aug 5, 2008 03:17 PM
blumpfish
Jun 18, 2006 09:23 PM
Sam268
Mar 2, 2004 10:20 PM
hybridb18
Aug 6, 2003 09:00 PM
