whats wrong??
Old Jun 2, 2002 | 01:22 PM
1hotintegra's Avatar
Default whats wrong??
about a month ago i got my oil changed... after 30 mins of driving after i got it, i turned the car off, came back 10 mins later started it and it died a few seconds after... tryed starting it and it wouldnt... got it started and it woulnd rev. over 4k. after runnin it for a lil bit it seemed fine. i thought they might have put too much oil in.. so i wasnt too worried. anyway.... a week ago i turned off my car and then started it about 2-3 mins later and it did the same thing... i let it sit for about a min. then it was fine... then yesterday the same exact thing... anyone know why this is happening??? it seems like it only happens when i turn off my car then start it up again in the next few mins (5-10 mins).. anyone??
Old Jun 2, 2002 | 02:57 PM
Jared's Avatar
Default Re: whats wrong?? (1hotintegra)
check and see if the ECM has any DTCs stored.
Old Jun 2, 2002 | 03:23 PM
Perfectionist's Avatar
Did you bother to check the oil level? Why wouldn't you worry about 'too much oil'?
Anyway, your symptom sounds similar to a hot soak restart problem. It's caused by a faulty temp sensor. The ECU thinks the engine is cold and enrichens the mixture, flooding the engine as a result. This isn't the only thing that could be causing the restart problem, but it is fairly common.
Old Jun 2, 2002 | 05:11 PM
Default Re: whats wrong?? (Perfectionist)
What is a DTC??? where and how much is the tempature sensor?
Honda_Si21
12
Mar 27, 2011 08:40 PM
b18c1v1c
12
Jan 4, 2008 10:31 AM
halloweenkid
Aug 15, 2007 04:52 AM
ringgold
Sep 17, 2006 10:51 AM
StreetEG
10
Jun 2, 2005 08:55 PM
