CODE 17 with other things
Old Jun 5, 2002 | 06:38 AM
Chris T's Avatar
Default CODE 17 with other things
I have a 90 rex with B16 and I hooked up a amp and after about 15 miles 17 popped up and my temp guage bounces up and down head lights dim and radio cuts out every time I hit the brake and with the head lights on the tac spikes even after I took the amp out I had the ground for the amp hooked up at the same spot as the tail light ground and after problem started I moved the ground also had the power wire running by the ECU and took everything out and same problem.any info helpful
Old Jun 5, 2002 | 08:32 AM
Chris T's Avatar
Default Re: CODE 17 with other things (Chris T)
Any guess would be helpful
Old Jun 5, 2002 | 11:33 AM
Perfectionist's Avatar
Where and how did you hook up the power for the amp?
Old Jun 5, 2002 | 01:57 PM
burnicq's Avatar
Default Re: CODE 17 with other things (Perfectionist)
Had this same problem in a 86 celica the wire at the battery was loose. Tightened everything down and everything was working again. Just my .02 cents
Old Jun 5, 2002 | 07:15 PM
minime's Avatar
code 17 is speed sensor code, but thats not all your problems. try checking the ground at the thermostat housing. have seen a lot of problems there.just a suggestion. good luck.
Old Jun 5, 2002 | 07:21 PM
fixhondas's Avatar
The tach, temp guage, and speed sensor are on the same fuse (#1 dash). I would check this circuit and definitely check the thermostat ground. Does your clock work?
Old Jun 6, 2002 | 07:51 AM
Chris T's Avatar
Default Re: CODE 17 with other things (fixhondas)
Yes the clock works but go`s out when I turn the lights on and then comes back on.
where is the thermostat ground,my guess is that your talking about the temp sensor.
Old Jun 6, 2002 | 12:49 PM
Chris T's Avatar
anything else wuold be helpful
Old Jun 6, 2002 | 12:51 PM
fixhondas's Avatar
The thermostat ground is right at the thermostat housing- one 10mm head bolt with a bunch of wires going to it- remove it, clean it, reinstall.
Old Jun 7, 2002 | 04:40 AM
Chris T's Avatar
OK,I cleaned the ground and still same thing
Old Jun 10, 2002 | 06:28 AM
Chris T's Avatar
OK,next
Old Jun 10, 2002 | 06:43 AM
YeuEmMaiMai's Avatar
you are drawing too much current that would cause the problems you are experiencing. try a slightly larger alt or battery or both. you may want to put some caps on your amp to use as reseve power 1 farad is about right at 20V
csc67
Sep 16, 2018 04:36 PM
bunkrd you
Aug 4, 2008 06:35 PM
kevinoneill
Audio / Security / Video
21
Feb 29, 2004 09:58 PM
agent marlon
Mar 30, 2003 06:29 PM
