question on changing head gasket
Old Jun 2, 2002 | 02:04 PM
ionic_slim's Avatar
Default question on changing head gasket
I'm changing out my head gasket and I was wondering do I have to change out the pston rings as well? Reason why I ask is because my oil comes out looking black and watery. The coolant has oil in it Every three days I have to fill in a quart of oil again. Am I losing oil because of the blown head gasket?
Old Jun 2, 2002 | 02:28 PM
S13 slide's Avatar
Default Re: question on changing head gasket (tazmoe)
did you do a leak down test? or compression test?
Old Jun 2, 2002 | 02:52 PM
Jared's Avatar
How many miles are on the engine? If it's quite a few then leave the piston rings, they'll be OK. If this is a new engine, the coolant in the combustion chamber probably will keep the rings from seating and they'll need replaced.
Old Jun 3, 2002 | 04:21 AM
ionic_slim's Avatar
Default Re: question on changing head gasket (Jared)
I did a compression check and it varys cyl 1:50-100, cyl 2:100-130 cyl 3:100-130
cyl 4:130. The engine was bought used and is a 99 LS. Should I change the rings then?
Old Jun 3, 2002 | 05:14 AM
Stewie's Avatar
The first thing you have to do is determine where your losing compression. Try puting some oil in the cylinders and see if the compression results are the same. If they are the same the rings are probably in good condition,.
Metal Typhoon
10
Jul 26, 2006 05:05 PM
Jer Del Sol
Nov 11, 2003 12:13 PM
G2turbo_terror
Jan 12, 2003 07:34 PM
turboD16
Nov 12, 2002 04:08 PM
