i got a b16 head that i am putting together and have some questions about the dowel pins...
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
i was missing the one in the middle on top part of head as well as the o-ring. the two dowels on the side are there though...since i was missing the dowel and o-ring in the middle, are there supposed to be o-rings on the side oil pin dowels under the two end cam caps? this is all i need to know and if anyone could answer this, thanks.
Re: i got a b16 head that i am putting together and have some questions about the dowel pins... (not
no, just the middle one uses the o-ring.
edit: wait a minute, r u talking about the rocker shaft orifices? if so, then those need o-rings.
[Modified by GreenDestiny, 7:39 PM 6/4/2002]
1 Post
the two dowels under the caps on the #1/timing belt side...those are the ones that i need to know if both need o-rings or not. there are none on there. i have a manual that says that there are supposed to be one or two (can't remember) but i got a printout of the cylinder head assembly from acura parts and it shows the middle o-ring and the dowel that i had to order but i didn't order two more because they weren't shown on the assmbly diagram that was printed for me. so i just need to know about those. i have the lost motion assemblys and everything else though. thanks.
the dowel pins dont use o-rings but the rocker shaft orifices (also under the #1 cam caps) do. sounds like u are talking about the dowels though so your good without the o-rings. sorry for the confusion.
1 Post
sweet that's all i need to know. thanks a lot.
Dowel pins are solid, SHUFFLE pins are hollow, so a bolt can go through them.
CucharasportEG95
09-16-2010 07:07 AM
