Idle adjustment screw?
Old Jun 6, 2002 | 09:55 AM
93SSPHatch's Avatar
Default Idle adjustment screw?
I have a 93 CX, and my idle adjustment screw somehow got stripped. I now want to replace it, because as it is now, I can turn the screw five times without any adjustment in the idle.
How do I replace this screw. . .
Do I have to take the whole throttle body off. . .
Do I need to buy a new throttle body gasket when I switch this screw?
Thanks for the help.
Old Jun 6, 2002 | 11:03 AM
bob01721's Avatar
Default Re: Idle adjustment screw? (93SSPHatch)
You should be able to get a screw at a dealership or a boneyard. You won't have to pull the throttle body. Just unscrew the old one and screw in the new one. (If you got it at a boneyard, check the rubber O-ring. I'm PRETTY sure it should have one.) Then, set your idle speed the way your manual tells you to.
Old Jun 6, 2002 | 01:26 PM
mick's Avatar
Default Re: Idle adjustment screw? (bob01721)
ya they do have an o-ring on them.. im having idle issues too :/
Crxdriver1989
Dec 19, 2017 01:28 AM
CHANCELLOR12
Feb 6, 2016 03:46 AM
924doorEG
Nov 19, 2007 08:15 AM
BDogggUT34
Jan 18, 2005 04:05 PM
oi-punx
Nov 14, 2002 02:01 PM
