Can someone help me? Distributor problem possibly
Old Jun 5, 2002 | 04:59 PM
gsrvx's Avatar
New User
Default Can someone help me? Distributor problem possibly
Today, my car began to sputter/hesitate while driving. Finally, car shut off. Noticed that somehow, a plug off the distributor was off. Put it on, car still doesn't start up. Mechanic happens to walk by and pulls a plug wire out, sticks a screw driver in there, and asks me to start the car. Car doesn't fire up. Says it's the dist.
Now i'm a newbie at this stuff...but I'm trying to learn from these experiences. Am I to replace the entire distributor? Is that cap and rotor? Or do I just replace the coil?
-Rod
Old Jun 5, 2002 | 05:04 PM
Doctor CorteZ's Avatar
Default Re: Can someone help me? Distributor problem possibly (RK)
could be the coil or the ignitor
just happened to a friend with a full MSD ignition , sputtered and ran like crap then gave up all together
turns out it was the ignitor , i think like 80 bucks OEM new
Old Jun 5, 2002 | 07:33 PM
minime's Avatar
its probally the coil or igniter, but i would replace both when one goes out its usually only a matter of time before the other one leaves you stranded. also check your plugs, worn plugs work them so hard they give out .they also dont like platinum plugs.i'm a honda tech i see this everyday. good luck
Old Jun 6, 2002 | 11:22 AM
bob01721's Avatar
Find out what's bad before you go replacing parts.
Do the same thing with the screwdriver at the coil. If there's a nice spark there, it's probably the distributor cap and/or rotor.
If there's no spark at the coil, it's probably the igniter unit or the coil itself. You can check the coil with an ohmmeter.
Old Jun 6, 2002 | 11:27 AM
gsrvx's Avatar
New User
Default Re: Can someone help me? Distributor problem possibly (bob01721)
Thanks for the help guys. I should also be getting my helms manual today which should assist me as well.
-rod
Thecargoddess
Jul 3, 2024 07:09 PM
1badcrx
May 9, 2009 12:58 AM
spunky424
Nov 7, 2004 06:17 AM
duckming
Jun 5, 2003 05:17 PM
dlric
Dec 13, 2001 03:55 AM
