!!! Tach will not work after engine swap!!!
Old Jun 4, 2002 | 04:14 PM
spart's Avatar
Default !!! Tach will not work after engine swap!!!
I have a 92 cx, I sold my old motor JDM B16 to get a ITR swap. I put the new swap in and the car runs fine, no problems at all except the tach wont work. I have a Canadian gauge cluster with the 8000 redline. I dont know if the gauge cluster is the problem or if the ITR wire harriness i used is the problem.
Old Jun 4, 2002 | 04:53 PM
RedlinedVTEC's Avatar
Default Re: !!! Tach will not work after engine swap!!! (spart)
Have you tried running a line directly to your ecu (at the corresponding pin for tach input) and another to the correct wire on the gauge cluster?
Old Jun 4, 2002 | 05:13 PM
Eg6_JDM's Avatar
i ran wire from behind the dash.....to a blue wire on the distributor
gauge works fine now
93 dx with b16a....cx cluster
Old Jun 4, 2002 | 05:15 PM
pelotudo's Avatar
How about posting only 1 thread for the same question??? Maybe that's the problem...
Old Jun 4, 2002 | 05:56 PM
riceboy's Avatar
Default Re: !!! Tach will not work after engine swap!!! (PeloTudo)
I think you need boost
Rttix1337
Feb 15, 2014 05:04 AM
aznm1tch
Feb 24, 2013 07:42 PM
evILL93eg
Aug 3, 2011 01:59 PM
Kinfer
Jan 13, 2008 09:47 PM
