OEM LSD in GSR tranny???
Old Jun 6, 2002 | 07:17 PM
InfamousRS's Avatar
Default OEM LSD in GSR tranny???
Would the OEM LSD from a 1st gen b16 tranny or ITR tranny fit into a GSR tanny? Is it somthing even worth while?
Old Jun 6, 2002 | 07:37 PM
Katman's Avatar
Default Re: OEM LSD in GSR tranny??? (InfamousRS)
I suggest an ITR LSD over a B16A LSD, if you plan to drop either one into your GSR tranny. I believe the B16 LSD is smaller in diamater which in turn means you'll have to swap in the B16's final drive ring as well. On the other hand, the ITR LSD alone, will drop into your GSR tranny without anything else (no FD ring needed, you reuse your GSR's FD ring).
[Modified by Katman, 8:38 PM 6/6/2002]
Old Jun 6, 2002 | 07:40 PM
InfamousRS's Avatar
Default Re: OEM LSD in GSR tranny??? (Katman)
Do you know about what I could get a ITR LSD for?
Old Jun 6, 2002 | 07:41 PM
Katman's Avatar
I've seen them range from $300-550 used. Personally I don't know of anyone selling any in my area.
Old Jun 6, 2002 | 07:47 PM
InfamousRS's Avatar
The $300 sounds good, now only if I can find one. What exactly is the ITR LSD called? Is it made by honda? Any info that could help me locate one would be good.
Old Jun 6, 2002 | 08:32 PM
Katman's Avatar
technically it's called a gear type Helical-torque LSD.
But there's not really a specific name for it, it just goes by 'Type-R LSD'. It is however different than other oem LSD's, like a JDM B16A's LSD.
Old Jun 6, 2002 | 08:47 PM
CivicEx95's Avatar
They're about $800 from Acura.
Old Jun 6, 2002 | 09:01 PM
InfamousRS's Avatar
Default Re: OEM LSD in GSR tranny??? (CivicEx95)
I would like to buy a used one. If I wanted to spend $800, I would get a quaffa (SP?)
killacam20
Apr 12, 2005 09:13 PM
NinjaTurtles
Mar 24, 2005 03:21 PM
InfamousRS
Jun 7, 2002 02:15 PM
jArceo
Apr 23, 2002 08:33 AM
