BIG TIME clutch problem !!!
Old Jun 2, 2002 | 07:36 AM
senpai's Avatar
Default BIG TIME clutch problem !!!
My clutch pedal doesn't seem to have enough room to allow me to put the engine into gear. I adjusted the pedal as far as I could.
Also, it makes this LOUD chatter when my foot is OFF the pedal. It is very loud, but it goes away once I step on the clutch.
Of course, this started happening about a month after we put in ACT XtremePP/street disc and CM flywheel.
What should I do? Thanks!
Old Jun 2, 2002 | 08:28 AM
earl's Avatar
Default Re: BIG TIME clutch problem !!! (maztur)
Broken spring in street disc?
Old Jun 2, 2002 | 10:26 AM
mechanik's Avatar
Default Re: BIG TIME clutch problem !!! (earl)
Does it sound like this in this movie clip at http://home.attbi.com/~mechanik08/soundofclutch.MPG ??
We experienced the same problems in a 93 EX with 170K. Chattering noise when clutch pedal was not pushed down. Noise went away when clutch was engaged. The mainshaft in the tranny is bad. We replaced the tranny with a 95 DX tranny. Gears are longer, but oh well, we want to swap anyway soon.
If you take out the tranny, and you can wiggle the mainshaft around (play in the mainshaft) than it is bad.
Old Jun 3, 2002 | 09:22 AM
senpai's Avatar
Default Re: BIG TIME clutch problem !!! (mechanik)
Phew, mine doesn't sound like that. Anyone else?
Old Jun 3, 2002 | 10:10 AM
dbman96's Avatar
New User
$10 says you popped a spring out of your clutch disk and it's wedging in sideways between the flywheel and pressure plate. Every honda clutch I've had has failed this way.
Old Jun 3, 2002 | 05:11 PM
senpai's Avatar
Default Re: BIG TIME clutch problem !!! (dbman96)
I sure as hell hope that you owe me $10 ...
bambbrose
Sep 6, 2005 04:21 PM
reeder321
Apr 1, 2004 01:47 PM
AzntaggeR
Mar 13, 2003 03:18 AM
garados
Dec 20, 2002 03:17 PM
RacerMike
Jul 22, 2002 07:26 AM
