vtec
Old Jun 4, 2002 | 10:25 AM
jojo7's Avatar
Default vtec
how can i put vtec onto my d15 i already have a d16 vtec head wha do i need to actually get the vtec to work? wha parts are needed
Old Jun 4, 2002 | 10:53 AM
sohc_boy's Avatar
Default Re: vtec (jojo7)
the head will bolt right on to your block. u will need a vtec ecu to engage vtec or use an rpm activated switch to engage vtec. both will require a lil wiring. if u get a vtec ecu u will need the harness as well or u will have to add some wires to yours. what year dx is it?
Old Jun 4, 2002 | 11:44 AM
jojo7's Avatar
Default Re: vtec (sohc_boy)
can i jus buy a and use that as the rpm switch that would turn the on? ohh and for the wiring can i jus hook the sensor and wha ever else needs to be hooked up jus to ground and power instead of buyin a harness. im doin this to my 89 civic 4 door LX automatic ..... ohh and for headers ... i buy for the 95 vtec head rite?
[Modified by jojo7, 8:48 PM 6/4/2002]
Old Jun 4, 2002 | 12:14 PM
.Ryan's Avatar
Don't Trust Anyone
vtec fluid duh!
Old Jun 4, 2002 | 12:30 PM
jojo7's Avatar
Default Re: vtec (SpoonSportsEF7)
whas VTEC fluid?
Old Jun 4, 2002 | 12:39 PM
il8apex's Avatar
New User
Back off, Spoon (Sorry, Jojo!). This guy has an honest question.
The correct answer to your situation: Yes, the head will bolt up. You will need additional electronics as stated above (thanks, guys!). Maybe someone on the board is willing to help or recommend a good garage? Anyone?
-Tom
[Modified by il8apex, 4:44 AM 6/5/2002]
Old Jun 4, 2002 | 12:54 PM
jojo7's Avatar
Default Re: vtec (il8apex)
thanx alot for your help i know that electronics are definately needed but which ones and can use a vtec controller instead of an ecu?
Old Jun 4, 2002 | 01:11 PM
erniecars's Avatar
you could use a vtec controller but i wouldnt recommend relying on that because there are other differences in the ecu that will help you in other ways such as fuel map and timing. I think you need to get a different distributor that will bolt up. not sure tho.
Old Jun 4, 2002 | 02:20 PM
slomofo's Avatar
GDD Member
You need, head, some wiring, ECU, a VTEC oil pump, and an oil line that runs to the head.
Old Jun 5, 2002 | 12:45 AM
kinesistech's Avatar
Default Re: vtec (slomofo)
No, your on drugs. Its a d not b. All you need is a head from 96-01 not 92-95 otherwise the bolt patteron on the head for the distributor will not line up right, and the newer distibutor is not the same for 88-91 and therefore not interchangeable. The bolt pattern on the 96-01 head is that same as 88-91 bolt pattern. Also some sohc heads use 1 longer headbolt, like zc's. Just look at the surface for the headbolt and if one is raised make sure you have a long one. Also make sure you use a headgasket for 92 and up because its metal and a little thinner than the updated metal gasket Honda has for your car.
Just use a vtec controller to activate vtec, that way you can control fuel and you dont have to buy a harness. Pretty much any civic header will fit your car.
Old Jun 6, 2002 | 06:36 AM
88_SC_CRX_Si's Avatar
New User
Try going here for some info, to get an idea of what you will need....
http://geocities.com/chipman_13/mini-me-parts.html
Old Jun 6, 2002 | 11:55 AM
sohc_boy's Avatar
Default Re: vtec (88_SC_CRX_Si)
vtec controllers will not work unless the car is rewired with a vtec ecu. u can just use an rpm activated switch to engage vtec very simple. also your car has the dual point t/b injectio i believe u might wanna swap that as well. the hybrid board also has quite a bit of info here is their site http://hybrid.honda-perf.org/. try and find an si trans for your lx that will make a pretty good difference in performance for u as the gearing is much shorter than your lx trans.
eaust96
Honda Civic (2001 - 2005)
Feb 4, 2014 05:59 PM
ClutchPapi
May 8, 2013 04:41 PM
95JDM
Jul 16, 2008 06:47 PM
zcdohcturbo
Apr 12, 2006 09:48 PM
si0385.
Dec 8, 2005 03:41 AM
