Running rich and tps
Old Jun 1, 2002 | 09:25 PM
S13 slide's Avatar
Default Running rich and tps
ok, heres my list of mods,
b18b, pr3 pistons, shot peened rods, arp rod bolts and head studs, fidanza 9lbs flywheel, clutchmasters stage 3, everything all balanced along w/ all new berings, seals and gaskets, i also have crower dual valvesprings and titanum retainers, and crower 404s but i left them out till i pass emissions. i have about 1 mile on my motor so far.now my problem is that my idle is really rough, i did a compression test and all four is at 240. and my plugs are black as hell. also my tps sencor is not corectly on, the voltage from the wires arnt to stock specs. would the tps deal cause my motor to run really rich and my idle to be rough? im guessing its rough cause its rich and sometimes it dies too. well TIA
Old Jun 2, 2002 | 12:27 AM
Jared's Avatar
Default Re: Running rich and tps (S13 slide)
The TPS would definitely do that, but are you setting any codes? Stock injectors won't flood a motor like that unless something is very wrong. What does your fuel pressure look like? Is your MAP sensor hooked up? any vacuum leaks? is the timing belt on properly?
Old Jun 2, 2002 | 01:51 AM
S13 slide's Avatar
Default Re: Running rich and tps (Jared)
hi, well no codes at all, and yes the map is on, no leaks and timming is correct, i'll double check that just to make sure, lets says it is a little bit off, would it do what i explained? thanks
Old Jun 2, 2002 | 01:36 PM
S13 slide's Avatar
bump. also would i be able to use a b18a throttle body? thanks
Old Jun 2, 2002 | 02:55 PM
Jared's Avatar
The B18A1 throttle body will bolt up to a B18B but is quite different. The B18B t/b has the map sensor mounted directly to the throttle body where the B18A has it on the firewall with a vacuum line attaching them.
Old Jun 2, 2002 | 04:09 PM
S13 slide's Avatar
so i just have to use the map from the g2? and mount it on the firewall? thanks
Old Jun 2, 2002 | 11:25 PM
Roger's Avatar
Sounds like the TPS sensor is bad. By any possible chance, are you running a ported throttle body thats different that your original ?? I had the same problem. I bought a JG throttle body and the car ran hella rich, boggs, and idles irratically, put back my original throtte body, and it ran smooth. Its gotta be the TPS sensor. Also, make sure that TPS sensor is on correctly.
Old Jun 3, 2002 | 05:39 AM
S13 slide's Avatar
Default Re: Running rich and tps (Roger)
well not a aftermarket tb, its stock but my tps broke, so i used my civic one and i wasnt able to adjust the voltage corectly, thanks
TahitianEG
Aug 7, 2007 11:43 AM
dornon13
Mar 1, 2006 06:59 AM
inline4
Nov 23, 2005 10:23 PM
wanttorace
Jul 12, 2003 10:52 AM
