p13 ecu
Old Jun 6, 2002 | 07:01 PM
servion's Avatar
Default p13 ecu
I've got a h22 motor in my '97 civic, and it idles like crap using the 'lude ecu. I switched (for grins) to my apare p28 ecu, and it idles great.
My EGR may not be wired correctly, so would that cause the problem because the p28 doesn't look for an EGR, or do you think my prelude ECU is screwed?
Old Jun 6, 2002 | 07:40 PM
Katman's Avatar
Default Re: p13 ecu (servion)
Yes. The EGR is a little biatch, and it does affect your idle while using the P13 ecu. And yes, the P28 doesn't look for the EGR valve. I don't think your P13 ecu is messed up, try it out in a stock prelude or somthing. I wish I knew the wire shematics for the H22 EGR, otherwise I'd share it with you.....
Old Jun 7, 2002 | 09:21 AM
servion's Avatar
Default Re: p13 ecu (Katman)
good to hear.... anyone know how to wire this?
Old Jun 7, 2002 | 10:40 AM
servion's Avatar
oops... I meant that I used a p72 GSR ecu... not a p28
birwin12
Aug 3, 2007 10:21 PM
ProjectTib
May 30, 2007 02:03 PM
tolowhb
Aug 11, 2003 03:27 PM
migo
Nov 13, 2001 04:13 AM
