crankshaft
Old Jun 3, 2002 | 11:08 AM
lysergican's Avatar
Default crankshaft
can any b-series crank be used in any b-series engine? for instance a b20b crank into a itr block?
Old Jun 3, 2002 | 11:10 AM
Spade's Avatar
Default Re: crankshaft (macroresin)
need more than the crank. Don't know mucha bout the subject.....best bet is a search on crank or crankshaft.
Old Jun 3, 2002 | 08:45 PM
allmtr's Avatar
Default Re: crankshaft (Spade)
yes but you need custom rods to make up for the longer stroke. the crv and ls cranks are the same, if you didnt know, both at 89mm. anyways, you cant use the crv rods either cuz there is a difference in deck height. good luck.
Old Jun 3, 2002 | 08:47 PM
allmtr's Avatar
Default Re: crankshaft (allmtr)
also the r/s ratio will be horendus cuz the new rods will be shorter than the crv. "Hey, whats my rod doing next to the gas pedal?"
Old Jun 4, 2002 | 12:27 AM
kinesistech's Avatar
Sounds like you want a 2.0 hype-r. What you need to do is increase bore size to 84mm. Thats the only difference between ls and crv.
93xsi
Oct 18, 2010 09:42 AM
bzyq2001
K Series
Feb 13, 2010 06:05 AM
omniman
Feb 7, 2010 10:04 PM
scooter
Mar 4, 2003 11:05 PM
SCsol
Mar 10, 2002 11:51 AM
