Hub removal.....HELP!
Old Jun 5, 2002 | 11:05 AM
apexii's Avatar
Default Hub removal.....HELP!
How the hell do I remove the hub from my preludes suspension? I have the rotor and caliper off, but I can't figure out how to get the damm hub off. I need to replace my wheel studs.
The hub seems to be pressed on, but I don't want to damage the wheel bearing in the removal process. The Helm is sort of vague, says to use 'special tool' for removal and a press. Do I have to remove the whole knuckle/hub assembly and take to a press? Can I get away with a gear puller instead?
Old Jun 6, 2002 | 05:19 AM
apexii's Avatar
Default Re: Hub removal.....HELP! (apexii)
Old Jun 6, 2002 | 06:46 PM
pips_ride's Avatar
i had the same problem with my 95 ex civic. took it to my cousins shop they just took a hammer and smacked the side of the joint to open the gap up a little bit and force takes it off the rest.
Old Jun 6, 2002 | 08:43 PM
Prelude Vtec 23's Avatar
Default Re: Hub removal.....HELP! (pips_ride)
Yeah its pretty hard to get out, I used a rubber mallet. But eventually got it to come out.
Old Jun 11, 2002 | 12:22 PM
apexii's Avatar
Default Re: Hub removal.....HELP! (Prelude Vtec 23)
Thanks for the replies, but it's still not coming off. I beat the living **** out of it and still will not budge. I need to know if I have to get it pressed out or not, specifically the prelude hub. Anyone?
Old Jun 11, 2002 | 03:09 PM
ninesecrx's Avatar
The bearings are going to break taking it off most likely, no matter what. Take the whole assembly off...upper and lower joints and steering knuckle and take it to a machine shop and let them pull it apart. You might find a spot though that you can get the new lugs in and out without pulling the thing off at all. I know we did it on a 91 crx.....Mike
Old Jun 11, 2002 | 05:05 PM
-TJ's Avatar
-TJ
Default Re: Hub removal.....HELP! (ninesecrx)
Yep, you'll need a new wheel bearing by the time you are done. On a Civic/CRX anyway, the inner race of the wheel bearing is split and when the hub comes out, 1/2 the inner race does too - stuck on the hub. Fun times.
Old Jun 11, 2002 | 06:18 PM
apexii's Avatar
Thanks! I cannot get the lugs out without removing the hub. There is no clearance. I have a broken lug that has over an inch missing and I can't even bang that one out now, with everything else removed. I was fearing having to remove the whole knuckle assembly but it looks like I have to. I had no idea a broken lug was this complicated! Thanks guys...
kornerk12
May 21, 2007 01:41 PM
jBj
Apr 17, 2007 12:54 PM
brospeed2001
Aug 5, 2003 06:05 PM
apexii
Jun 6, 2002 07:56 AM
InfamousRS
Feb 11, 2002 09:36 PM
