weird vtec pressure switch problem. code 22. what else to check
Old Jul 5, 2004 | 09:05 AM
Bailhatch's Avatar
Default weird vtec pressure switch problem. code 22. what else to check
just put in a sohc ZC in a 94 hatch. vtec no worky. code 22...vtec presure switch.
Checked the wiring and even ran wires out of the harness directly to the ecu.
the switch has continuity between the trerminals (which it should) and i have tried another known good sensor. The only part that doesn't look right is that I only get 2.88v at the blue/black wire with the key on and it should be around 12v. I have tried 2 p28s with no luck.
Anyone run into this before? any more ideas?
Old Jul 12, 2004 | 01:43 PM
Bailhatch's Avatar
Default Re: weird vtec pressure switch problem. code 22. what else to check (Bailhatch)
help me out if ya got any ideas!
Old Jul 12, 2004 | 05:39 PM
staticrex's Avatar
I had the same problem and all it was was low oil. I did replace the switch any way though.
UDUBdriver
Engine Management and Tuning
Sep 4, 2011 07:04 AM
HondaFanBoy
Jun 16, 2005 11:25 AM
Blake97GSR
Nov 7, 2003 06:01 AM
shonnys92si
Jan 20, 2003 11:45 PM
