OK to reuse ARP Head bolts?
Old Jul 3, 2004 | 02:52 PM
RTW DC2R's Avatar
Default OK to reuse ARP Head bolts?
Im getting conflicting info so to whether or not you can. Im going from a high comp ratio all motor setup to a high boost turbo set up, and have since removed the head for a new bottom end that is being built. Can I reuse the ARP head bolts for the boost set up? Ill be looking at around 25psi. Thanks
Old Jul 3, 2004 | 03:41 PM
Top Ramen's Avatar
Default Re: OK to reuse ARP Head bolts? (RTW DC2)
Yes, you can, but the torque specs change. They (ARP) can tell you what the specs are for torquing them down on the second use.
Keenor
Feb 17, 2011 09:18 AM
oranginal
May 2, 2006 11:14 AM
fastfu
Aug 10, 2005 04:41 PM
dumpeDc2
Nov 4, 2004 08:07 AM
