type r distributor??
Old Jul 1, 2004 | 09:15 PM
gundamgsr's Avatar
Default type r distributor??
i have a gsr block with a jdm itr head. i keep getting reacurring code 4's (crank position sensor). should i ditch my gsr dizzy for a type r dizzy or are they basically the same?
Old Jul 1, 2004 | 09:30 PM
Kwuaymaikrup's Avatar
Default Re: type r distributor?? (gundamgsr)
The code you are getting has nothing to do with the distributor. It is the crank sensor code. What ecu are you running? Maybe the ecu is looking for a crank sensor and maybe your engine does not have one. *shrug*
Old Jul 1, 2004 | 09:48 PM
gundamgsr's Avatar
thats funny because the haynes says if the sensor is bad then change the dizzy. plus its locatewd inside the dizzy. hmm.
Old Jul 1, 2004 | 10:26 PM
Default Re: (gundamgsr)
Really? I was thinking it is the sensor on the oil pump. I am running an ITR oil pump on my setup and there is a sensor on the oil pump. I was ASSuming that this was the crank position sensor. Hmmm....
Old Jul 2, 2004 | 01:52 AM
Fobtions's Avatar
Default Re: (Kwuaymaikrup)
the sensor is inside the distributor. and when you get this, you inevitably have to replace the whole thing.
the oil pump sensor is something else.
Old Jul 2, 2004 | 06:39 AM
gundamgsr's Avatar
im hoping it resets
Old Jul 2, 2004 | 11:18 AM
Jimmy's Avatar
Global Moderator
change distributors and reset your ecu
Old Jul 2, 2004 | 11:35 AM
Sack Master's Avatar
Default Re: (Jimmy)
The gs-r distributor would be fine to use. But if the crank angle sensor is bad then it is bad. Change it.
Old Jul 2, 2004 | 04:53 PM
gundamgsr's Avatar
i changed out the dizzy. no problems now. thx for all feedback. btw its a b16 dizzy.
schlong1
Oct 19, 2008 05:38 PM
EGhatchguy
Nov 11, 2007 05:26 PM
SwappedLSHatch
Apr 13, 2006 01:33 PM
YellowR2000x2
Mar 4, 2005 04:29 PM
Nvious R
Oct 28, 2003 06:27 PM
