LS/VTEC tuning (running too lean)
I just installed an Air Fuel gauge and after warm up the car is always lean. The only time I see Stoick is when the throttle is cracked hard but than the computer compensates and returns to lean. Sometimes it's off the scale until I blep the gas.
I am running a LS VTEC with the followling mods.
LS- block, crank, rods.
b16a- pistons, head, oil pump
Gsr- Cams
Always run 94 octane with a booster on the side.
O2 sensor is one month old
Timing is set @ 12 deg. BTDC
My Ecu has the following chips- Mugan, Spoon, Minds.
all 3 have the same outcome, TOO LEAN
Do I need a fuel pump? Fuel rail?
Are the B16a's Injectors not keeping up? Should I use b-20?
How can I richen up my combustion?
Hyper Duck Tuning says all of these chips should be running righ.
Any help would be appreciated.
Gsr- Cams
InfamousRS
May 29, 2002 08:39 AM
infamousALLMTR
Apr 16, 2002 09:40 PM
