d17 tranny on EK?
I don't know if they can be mix and matched, but I can tell you that they're pretty terrible! Check over on 7thgencivic.com and see how many people have had them explode on them! Several people have had them do it more than once.
I am almost 100% sure that it will fit because I have bolted the D15B block to my D17 gearbox (which is in my 03 Civic shell) and it bolted directly with no problems at all. So I believe that since the D17 gearbox can bolt to the d15B Block then it should bolt directly to the D16Y8 or the Y7 blocks as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kezay »</TD></TR><TR><TD CLASS="quote">I am almost 100% sure that it will fit because I have bolted the D15B block to my D17 gearbox (which is in my 03 Civic shell) and it bolted directly with no problems at all. So I believe that since the D17 gearbox can bolt to the d15B Block then it should bolt directly to the D16Y8 or the Y7 blocks as well.
you must of done a lot of wiring changes to make that work.....d15b in a 03 civic...bah...
</TD></TR></TABLE>you must of done a lot of wiring changes to make that work.....d15b in a 03 civic...bah...
