sensor for fuel?
Old Jul 2, 2004 | 02:47 PM
IVI's Avatar
IVI
Default sensor for fuel?
is there a sensor for fuel delivery?
i think to believe that my injectors do not shut off they are dumping too much fuel to the motor and totally bogging the motor.
Old Jul 2, 2004 | 02:56 PM
devnull's Avatar
First check and replace your fuel filter. (most likely)
Second check your FPR. (bad or blown diaphram)
Third check your injectors (this means you have to send them in to get cleaned).
Old Jul 2, 2004 | 03:24 PM
IVI's Avatar
IVI
Default Re: (qi_doy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qi_doy &raquo;</TD></TR><TR><TD CLASS="quote">First check and replace your fuel filter. (most likely)
Third check your injectors (this means you have to send them in to get cleaned).</TD></TR></TABLE>
fuel filter was replaced already
fpr i guess possible, but i am getting fuel delivery. it seems the injectors dont pulsate, they are constant on.
i have a spare set of injectors and spare fuel rail so ill see.
btw this all started when my tps broke and i took off my IM and when i put it all back thats when it started doing this.
its not the computer, 2 others were tried.
Old Jul 2, 2004 | 03:50 PM
devnull's Avatar
Well that's a horse of a different color &lt;-- Give you two points for the movie title
Anyway since you broke your TPS it's probably that. Regardless of if you put a new one on you need to make sure it was calibrated correctly.
Old Jul 2, 2004 | 04:11 PM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qi_doy &raquo;</TD></TR><TR><TD CLASS="quote">Well that's a horse of a different color &lt;-- Give you two points for the movie title
Anyway since you broke your TPS it's probably that. Regardless of if you put a new one on you need to make sure it was calibrated correctly.</TD></TR></TABLE>
wizard of oz ?
the new tps came on a new throttle body, used but new for me. it had never been removed before.
eg93LS
Jan 26, 2010 12:51 PM
harryr34
Jun 7, 2005 01:23 PM
drjulian
Sep 9, 2004 01:09 AM
ludedude95
Feb 15, 2004 06:50 PM
iperez
Feb 19, 2003 09:05 AM
