NEED HELP, Throttle Issues
Old Jul 1, 2004 | 06:53 PM
notstock93's Avatar
Default NEED HELP, Throttle Issues
I am truly in need of help here, I just installed a throttle cable for my 93 integra with a b18C1. I used a B18C1 throttle cable, and it was too short, so I had to modify the throttle bracket to get it to work. Now, the throttle stays open when the clutch is depressed causing the revs to raise, the pedal is extremely hard to move, and my S-AFC tells me there is always anywhere between .5 to 1.1% throttle opening. WTF.
My gut tells my its something to do with the bracket, but I have no idea why it would be acting this way, the bracket itself doesn't actually touch any part of the cable, only the adjustment screws (which are all the way to loose, BTW)
Even if the throttle was too tight, and it caused the car to rev slightly during shifts, that doesn't explain the pedal stiffness.
If I don't get this fixed, the car is going in the paper Monday, so any help would be greatly appreciated.
Hiboost 2.0
May 17, 2013 05:33 PM
rattlecannedEF
Jul 4, 2009 04:52 AM
hamst3r3x
Dec 10, 2007 09:41 PM
boostingisfun
Aug 27, 2007 04:54 PM
notstock93
Jul 2, 2004 11:31 AM
