CTR pistons have 25 written on top of them???....they're supposed to be standard bore. Are they?
I don't have an outside mic so I can't measure them. The 25 is written on top of all 4 of the pistons. What does this mean? The person I bought them from said that they were standard and they came in the factory box?
Re: CTR pistons have 25 written on top of them???....they're supposed to be standard bore. Are they?
the 25 stands for their 25thou oversize piston.
those are not standard bore pistons...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">the 25 stands for their 25thou oversize piston.
those are not standard bore pistons...</TD></TR></TABLE>
I just went out for test fit into a block I know has an 81mm bore and guess what..... They are to big!!!!! Do you think I should just get the block I was going to put these in bored or try to get some 81mm pistons?
to get the best life/performace out of that engine you should have it over-bored and honed with those pistons and new rings. it will guarentee a perfect ring seal and no oil consumption problems down the road.
just make sure the rings you have are the over sized ones for those pistons as well.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">to get the best life/performace out of that engine you should have it over-bored and honed with those pistons and new rings. it will guarentee a perfect ring seal and no oil consumption problems down the road.
just make sure the rings you have are the over sized ones for those pistons as well..... </TD></TR></TABLE>
Cool. The block I was going to use has a fresh hone but is still 81mm. I guess I am going to have to make another trip to the machine shop!!!!! is 13021-pr3-004 the part # for the oversized rings(81.25mm)?
no idea on the part numbers............call up the locall dealer and find out or ask someone else on the board who may know......
The 25 means .25mm or .010"
Re: (qi_doy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qi_doy »</TD></TR><TR><TD CLASS="quote">PR3 is not a CTR piston. It is a stock Gen 1 B16A Piston (10.2:1 compression)</TD></TR></TABLE>
You're an idiot!!! that is a piston RING part number. All b series pistons(except b20) use the same rings they just vary in size. If you don't know what you are talking about stay off of my threads!!!!!
I'm the idiot? Your the one asking if a 81.25 mm piston will fit in a 81mm hole. Geee I wonder. I think if you go to Arias and have them machine you a Square piston it will fit to.
Secondly Why don't you teach yourself how to burn a chip. It's not that hard. A little brain power and some reading and you should be able to do that.
Though your trying to but a piston in hole to small.
Oh and the CTR/ITR piston rings are different then regular PR3 or P30 or P72 Rings. But you knew that too.
Next time don't try to be such an *** and you might further.
Re: (qi_doy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qi_doy »</TD></TR><TR><TD CLASS="quote">I'm the idiot? Your the one asking if a 81.25 mm piston will fit in a 81mm hole. </TD></TR></TABLE>
his question was more towards the scribe on the piston, he came to his own conclusion that the 25 meant .25mm over. People need to chill. was a simple question that got a simple answer!
Re: (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi »</TD></TR><TR><TD CLASS="quote">
his question was more towards the scribe on the piston, he came to his own conclusion that the 25 meant .25mm over. People need to chill. was a simple question that got a simple answer! </TD></TR></TABLE>
EXACTLY!!!Thanks alot. People just get mad when they are wrong
gi_doy
https://honda-tech.com/zerothread?id=101134
Modified by hondaguyef at 7:43 PM 7/8/2004
gi_doy
Re: (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">
You're an idiot!!! that is a piston RING part number. All b series pistons(except b20) use the same rings they just vary in size. If you don't know what you are talking about stay off of my threads!!!!!</TD></TR></TABLE>
no need for name calling.
Re: (HulkSmash)
I apoligize<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HulkSmash »</TD></TR><TR><TD CLASS="quote">
no need for name calling. </TD></TR></TABLE>
Re: (hondaguyef)
what motor is this going in???
i just got done doing the exact same thing to my b16. keep the oversized pistons and bore the block like it was said above. itll give you fresh cylinder walls.
just for the record, i do believe that is the part number. it definatly does say PR3 in it.
Re: (anothersickhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothersickhatch »</TD></TR><TR><TD CLASS="quote">what motor is this going in??
just for the record, i do believe that is the part number. it definatly does say PR3 in it.</TD></TR></TABLE>
1). B18a (not LSVTEC)
2). The part # is correct. People just try to be smartasses and then find out that they are wrong
