lsvtec... timing belt install... confused
Old Jul 6, 2004 | 11:08 AM
lsvtec101's Avatar
Default lsvtec... timing belt install... confused
how do i install these? I put the pulley on first but then the plate wont go over the key? do i need the crank plate? can somone explain what im doing wrong?
Old Jul 6, 2004 | 11:29 AM
blackhatchb20's Avatar
Default Re: lsvtec... timing belt install... confused (lsvtec101)
put the key on the crank, slide the BIG sprocket over that, it should seat in there, and put the little piece where its bending going out...not bending going in...but outm you can see what i am talking about it you look at it directly on make sure it bends away from the crank...and i dont think it supposed to go over the key
Old Jul 6, 2004 | 11:44 AM
lsvtec101's Avatar
Default Re: lsvtec... timing belt install... confused (blackhatchb20)
Ok, im about to put the plate on now in the pic, when i push the plate to the pulley it pushes the key into the pulley. do i have the wrong key? do i need a longer one?
edit: even if i did get a longer key it doesnt clear the plate..............
Old Jul 6, 2004 | 11:50 AM
96dxB16's Avatar
looks fine to me
there should be another key for the crank pulley
Old Jul 6, 2004 | 11:51 AM
lsvtec101's Avatar
Default Re: lsvtec... timing belt install... confused (96dxB16)
damn i need 2 keys?
Old Jul 6, 2004 | 12:21 PM
I3ackfire's Avatar
OT man, but are you building this in your bedroom??
Old Jul 6, 2004 | 12:28 PM
Default Re: lsvtec... timing belt install... confused (I3ackfire)
damn, something just doenst look right...
edit: my gears on the oil pump always had a little key built into it, then i just had 1 key for the crank pulley...not sure what u got there...
here are some pics i am talking about, i'm not sure where u got that oil pump drive, but it looks wrong...here is what i have always had(the pics should work)
see a key made into the gear
on the crank
the key goes in that open spot and the plate goes over that...
hope this helps..
Modified by blackhatchb20 at 1:42 PM 7/6/2004
Old Jul 6, 2004 | 03:27 PM
lsvtec101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ackfire &raquo;</TD></TR><TR><TD CLASS="quote">OT man, but are you building this in your bedroom??</TD></TR></TABLE>
both bedroom and garage.....
EdSales
Jan 15, 2012 02:01 PM
oranginal
Jul 3, 2009 02:20 PM
Jabinya
Aug 28, 2007 06:50 PM
Bullet113
Dec 7, 2006 02:16 PM
EG_Civic_Si
Mar 1, 2006 06:14 PM
