Head
Old Jul 5, 2004 | 09:09 AM
vti2's Avatar
Default Head
Hi, I have a fully build B16 with 84mm bore.
My question:
Do i need to mashinate the combustion chamber on my head to 84mm also or can i let it with the stock bore?
Old Jul 5, 2004 | 10:54 AM
JDMotive's Avatar
Default Re: Head (vti2)
You do not need to open up the combustion chamber to 84mm,unless you want lower compression.
Old Jul 5, 2004 | 11:01 AM
vti2's Avatar
Default Re: Head (JDMotive)
So i can put the stock head with it?
Old Jul 5, 2004 | 01:22 PM
JDMotive's Avatar
Yes,unless you have custom pistons with a wider dome.If theyre off the shelf 84mm high compression pistons than you might need to widen the chamber,but ive never had a problem with the stock chamber on 85mm 15:1 pistons.
Old Jul 5, 2004 | 08:13 PM
Fuxican's Avatar
I'd open up the chamber to the bore. Its going to help the flow of the head. You wont be adding much ccs to the head, plus by going with the bigger bore, you've raised your compression already. Having more airflow is worth the minimal compression loss.
BLU CIVIC
11
Nov 3, 2009 05:35 AM
canada-civic
Mar 1, 2006 07:50 AM
asubennett
Jun 10, 2004 04:10 PM
OBD-One-Kanobe
Sep 17, 2001 02:54 PM
