What tool to use to tighten stuff like this?
Old Jul 3, 2004 | 10:30 AM
xavior66's Avatar
Default What tool to use to tighten stuff like this?
Long story short, I'm about to change out the right side (if you're sitting in the car) rack end on my P/S gearbox...
Illustration No. 1 is the part I'm changing. Now here's where I'm stuck at...The Helm's manual calls for this part to be tightened to 40 ft-lbs. But the problem is that I can't tighten it using a socket cuz it won't fit right on it. I can use adjustable wrenches to tighten it, but not to torque it to specs.
So my question is what tool(s) would I need to tighten it to 40 ft-lbs. correctly? I'd use a torque wrench (duh) but like I said, I can't get any sockets to fit onto the rack end. TIA!
Old Jul 3, 2004 | 12:25 PM
xavior66's Avatar
Default Re: What tool to use to tighten stuff like this? (xavior66)
Bump!
Old Jul 3, 2004 | 12:55 PM
DonF's Avatar
The tool you need is called a crowsfoot, avail. at Sears, will fit the torquewrench.
Old Jul 3, 2004 | 01:14 PM
Kendall's Avatar
Correct, a crowsfoot is what you need. It will allow you to attach a "wrench-like" end to an extension coming from the torquewrench. There is a torque correction factor when using a crowsfoot that you must consider, otherwise you will get incorrect torque.
Old Jul 3, 2004 | 01:21 PM
xavior66's Avatar
Default Re: (Kendall)
Thanks guys! I'll look into it!
Old Jul 3, 2004 | 02:08 PM
Chiovnidca's Avatar
Default Re: (xavior66)
Don't forget to use a new lock washer.
Old Jul 3, 2004 | 09:43 PM
dfoxengr's Avatar
Default Re: (Chiovnidca)
im too lazy for most torquing procedures unless it is engine internal so i just guess on everything else on the car.
Old Jul 4, 2004 | 09:26 AM
RCautoworks's Avatar
Default Re: (hybridvteceg)
You can't buy the right size at sears though, they stop at 18 and you need a 19, well at least on the outer tide rod, the inner might actually be a 17.
wc4ohio
Apr 21, 2011 10:58 AM
Clayton
Honda Civic (2001 - 2005)
Oct 29, 2009 12:15 PM
G2DAB18
Dec 29, 2005 12:06 PM
drunknbass
Apr 13, 2004 07:03 PM
Hayasa15
May 27, 2003 05:29 AM
