Internals of VSS; what kind of grease??
Old Jul 1, 2004 | 05:41 PM
tzenisj's Avatar
Default .
Old Jul 1, 2004 | 06:15 PM
TIRENECK's Avatar
Default Re: Internals of VSS; what kind of grease?? (civic_rice)
if your stock cluster was working fine before then it is not the VSS, bad wiring.
Old Jul 2, 2004 | 05:28 PM
Sliced Beard's Avatar
if it does not work it is result of a bad electrical component in the VSS itself
either that or there is a short in the wire somewhere
Old Jul 2, 2004 | 08:34 PM
TIRENECK's Avatar
from my knowledge the VSS doesnt need any grease because it deeps into the tranny where it get lubricated from the oil the tranny has.
Old Jul 2, 2004 | 08:53 PM
mmuller's Avatar
Mad Scientist
you'll be fine. its is so that the key dont stick, thats all.
Old Jul 2, 2004 | 09:20 PM
mmuller's Avatar
Mad Scientist
you are talking about the drive link that goes in the middle of the actual ''drive'' part and the sensor ,right?
Old Jul 3, 2004 | 12:37 AM
blackhatchb20's Avatar
its not your VSS...check your wiring...
VSS means 1 thing...vehicle speed sensor...it has NOTHING to do with your tach
edit your tach should have atleast 4 wires
1 positive
1 negative
1 for lights
1 signal - the signal wire, hook it up to the orange/blue wire on your dizzy plug
Old Jul 3, 2004 | 01:45 AM
my alarm did the same thing....it was a grounding issue, and when my tach was jumping it was a grounding issue as well...check the ground on your thermostat housing..make sure its tight, check all you major grounds on the motor
80 dolla crx hf
Jan 17, 2010 09:39 PM
B18CTYPER2000
Sep 8, 2009 06:44 AM
civic08
Feb 28, 2008 09:22 PM
ULTRAdC2
Feb 1, 2007 05:27 PM
Mike D
May 15, 2003 06:36 PM
