best valvetrain (poll)
Old Jul 4, 2004 | 03:27 PM
londa hover's Avatar
Default best valvetrain (poll)
who makes the best valvetrain?? and what do you guys think about mixing it up like itr valves skunk2 retainer and toda springs.
Old Jul 4, 2004 | 10:39 PM
JDMotive's Avatar
Default Re: best valvetrain (londa hover)
Every company makes good valvetrain,the best for your setup mainly depends on what you are using it for,as some would be better than others for certain applications.
Old Jul 5, 2004 | 01:30 AM
Quitripin's Avatar
i agree
Old Jul 5, 2004 | 02:52 AM
Xsi's Avatar
Xsi
It really depends on your cams, theres no point in going overboard and spending a lot more than you need to. What is your setup?
Old Jul 5, 2004 | 11:11 AM
wickedEFguy's Avatar
how come rocket valvetrain isn't on the poll?
Old Jul 5, 2004 | 02:03 PM
megotvtec's Avatar
Default Re: (Xsi)
supertech needs to be on there too!
sombody who hasnt voted add supertech and rocket
Old Jul 5, 2004 | 03:42 PM
Big Teggie's Avatar
I use RM valvetrain for my personal motor.
What kind of cams will you be using? This should help you decide on what you need.
Old Jul 5, 2004 | 10:41 PM
GSRswapandslow.
Guest
Posts: n/a
i use RLZ valve springs, retainers, and cams
Old Jul 6, 2004 | 07:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">It really depends on your cams, theres no point in going overboard and spending a lot more than you need to. What is your setup?</TD></TR></TABLE>
i have skunk2 stage1 cams that produce power to 8700
Old Jul 11, 2004 | 02:04 PM
megotvtec's Avatar
you can never go wrong w/ supertech.
Old Jul 11, 2004 | 02:27 PM
G U E C O's Avatar
portflow
Old Jul 13, 2004 | 05:32 PM
GSRswapandslow.
Guest
Posts: n/a
Default Re: best valvetrain (Manuel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel &raquo;</TD></TR><TR><TD CLASS="quote">ALANIZ or Port Flow make more Air Flow
420 </TD></TR></TABLE>
no they don't
BAN
Old Jul 16, 2004 | 03:17 PM
0-60pdog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by londa hover &raquo;</TD></TR><TR><TD CLASS="quote">
i have skunk2 stage1 cams that produce power to 8700</TD></TR></TABLE>
I believe that skunk stage 1 cams do not require any valve train changes. however if you dont have a b16 or typeR head then you might want to add dual springs (typeR set or skunk2......) at least to your intake side.
Old Jul 16, 2004 | 03:59 PM
Default Re: best valvetrain (JDMotive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0-60pdog &raquo;</TD></TR><TR><TD CLASS="quote">
I believe that skunk stage 1 cams do not require any valve train changes. however if you dont have a b16 or typeR head then you might want to add dual springs (typeR set or skunk2......) at least to your intake side.</TD></TR></TABLE>
are you sure my stock valves can hold up to 8700rpm's???
Old Jul 16, 2004 | 04:02 PM
0-60pdog's Avatar
what motor are you running!!!!
Old Jul 16, 2004 | 07:10 PM
megotvtec's Avatar
Default Re: best valvetrain (0-60pdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0-60pdog &raquo;</TD></TR><TR><TD CLASS="quote">what motor are you running!!!!</TD></TR></TABLE> b18c1
Old Jul 16, 2004 | 09:48 PM
0-60pdog's Avatar
Default Re: best valvetrain (megotvtec)
if you plan on reving to 9000 every day all day then your stock valve train will not last very long and you will probably end up floating a valve. If i remember correctly skunk's stage 1 cams are close to civic type R(ctr) cams and i have seen many GSR's with ctr cams run to 9000 rpms. So it will work but the question is how long!!!!! If you can get your hands on some TypeR valves, springs and retainers that would be choice.
I personally don't like mixing parts in the valve train for a few reasons. Basically skunk designed their parts to fit on Honda heads and work with other skunk parts. Not to say they won't work with other parts from different company's, there just not designed to!!!!!!!
If you really feel the erge to bye a valve train I suggest to use typeR valves and skunk everything else.
Old Jul 16, 2004 | 10:02 PM
Sunrise City Rider's Avatar
Don't forget about REV Valves
http://www.revvalves.com
Old Jul 17, 2004 | 11:18 AM
vti444's Avatar
im gettin mixed answers on which valves for jun 3 in b16a2. 2 people ive spoke to said stock are fine as they have them and no probs but then others say i should change them.
for daily driver and will rev to 9000
Old Jul 23, 2004 | 04:23 PM
Milano98teg's Avatar
Default Re: (vti444)
up for u
Old Jul 26, 2004 | 12:15 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: best valvetrain (Sunrise City Rider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sunrise City Rider &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget about REV Valves
http://www.revvalves.com</TD></TR></TABLE>
Old Jul 29, 2004 | 06:59 PM
CRX T-Si's Avatar
Default Re: best valvetrain (bruceleeroy)
I was going to get supertech valve springs and retainers from earl.
Due to $$(everything is $$) I put back the stock ones for now but keeping my revs to 8k on a slightly ported/polished b16 head. Do you think this is safe?? 8k MSD pill is in my 6al.
Old Jul 29, 2004 | 10:08 PM
SYD's Avatar
SYD
Default Re: best valvetrain (CRX T-Si)
yes 8k is safe.
Old Jul 31, 2004 | 05:50 PM
megotvtec's Avatar
what are supertech valves good for? (rpm wise)
Old Aug 1, 2004 | 07:59 AM
sinister6's Avatar
for some reason, those sort of internal parts i prefer using the parts from same company.. so they will fit and wont have any clearence problems..i vote for Toda..
