Cold Start Idle Problem
Old Jul 3, 2004 | 08:05 PM
hatch4raceb16's Avatar
Default Cold Start Idle Problem
I have a 1990 Integra RS. When I start the car when its cold, it idles up to about 2300 rpm and sometimes fluctuates up and down from 800 to 2300.
After about 3-4 minutes, it stops and idles normal, but slightly, and I mean slightly rough.
Any idea what this is? I am guessing a sensor. Maybe TPS or map. If you know what it is please tell me how to check it .
THANKS...............
Old Jul 3, 2004 | 09:08 PM
coldfish's Avatar
sticky fast idle thermo valve.
Old Jul 4, 2004 | 09:22 AM
ELAMINT5's Avatar
Default Re: (coldfish)
how can it be fixed, my car does the same thing? i thought it was a vacum leak and could not find it.
Old Jul 5, 2004 | 02:59 PM
Default Re: Cold Start Idle Problem (hatch4raceb16)
Old Jul 5, 2004 | 04:42 PM
ELAMINT5's Avatar
anybody!
Old Jul 6, 2004 | 06:05 AM
coldfish's Avatar
Default Re: Cold Start Idle Problem (ELAMINT5)
usually happens bcos of 2 reasons.
1. IACV dirty/clogged - clean it
2. you did a throttle body coolant bypass the wrong way (sealing both ends of the coolant lines instead of joining them) - u need to join the lines and make sure coolant flows right thru.
Old Jul 6, 2004 | 06:13 AM
mmuller's Avatar
Mad Scientist
Default Re: Cold Start Idle Problem (coldfish)
as somebody sayd above, check your fitv. take it out and shake it, if it rattles, then it needs to be fixed. to fix it take it apart and screw the little white screw back in.
Old Jul 6, 2004 | 06:33 AM
Default Re: Cold Start Idle Problem (mmuller)
what is fitv
and how do i check the coolant bypass>?
Da9austinRacing
Mar 19, 2011 07:42 AM
ericstambaugh07
Jan 20, 2007 01:52 AM
deeweezy187
Dec 3, 2005 08:50 PM
Wicked Sol
Mar 6, 2003 05:49 AM
Kamin
Jan 12, 2002 08:43 AM
