setting my tps
Old Jul 1, 2004 | 07:12 PM
thinknology's Avatar
Default setting my tps
Alright I've read the articles and all and i know how to set my tps but i can't get it to work and i know it's because im an idiot and don't know how to work my voltmeter because not matter where i place the tps i get a reading of 1.3 and one last desperate hope when throttle is "closed" does that mean car is idling or off? please someone let me know how to work my freakin meter... thanx
Old Jul 2, 2004 | 02:04 AM
Xsi's Avatar
Xsi
The throttle is closed when it is shut, meaning you don't have your foot on the throttle. The car isn't idling but the key is on acc. Are you sure you are measuring the right wires?
http://www.integra.orcon.net.nz/tps may help
Old Jul 2, 2004 | 10:53 AM
Spunkster's Avatar
Default Re: setting my tps (thinknology)
The car has to be running to read and adjust the TPS.
Old Jul 2, 2004 | 11:32 AM
doublejz's Avatar
Default Re: setting my tps (Spunkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster &raquo;</TD></TR><TR><TD CLASS="quote">The car has to be running to read and adjust the TPS.</TD></TR></TABLE>
wrong, so when you adjust WOT to 4.5 or whatever your gonna be sitting there bouncing off the rev limiter.
as long as you have the key at the on position it will work.
you can actually remove the tb and adjust it by measuring resistance through the tps.
Old Jul 2, 2004 | 03:28 PM
Default Re: setting my tps (doublejz)
alright ive set it jsut about as close as i can its at .449 and still it doesnt run right it jumps around at first then after a little it idles ok but when push the throttle to fast it bogs it down and i still got blackish smoke comin out the exhaust
Old Jul 2, 2004 | 03:52 PM
HELP :-(
Old Jul 2, 2004 | 04:44 PM
Xsi's Avatar
Xsi
When I set mine I set it to 0.45 like the manual said but I still had idle problems. I then measured the TPS on my stock TB (it was still set from the factory) and it was 0.32V.
So I set my new TPS at 0.32 and it has been fine ever since.
Do you have someone else you know with the same car so you can measure their TPS?
Old Jul 2, 2004 | 04:47 PM
Default Re: (Xsi)
well i hope i can figure out something cus its definetly not running right i put my stock ecu chip back in instead of spoon and its running a little better but still i think its getting choked out ,,,, anyone know there tps volt. for a crx si B16A (or del sol vtec)?
Old Jul 5, 2004 | 10:04 PM
Tad's Avatar
Tad
Default Re: (thinknology)
hmm,
maybe try the voltage Xsi used, .32V
he said it worked for him, its worth a shot at least!
btw i tried setting my tps today, and failed,
couldnt figure out how to get a reading off it...
i hooked a wire to one of the pins(pain in the butt to get the probe back behind the tb)
and used that to probe..
i put positive on that wire, and neg on lotsa stuf(batt pos/neg, various grounds) and got nothing but garbled readings bouncing around..
so dont feel alone.
Old Jul 5, 2004 | 10:16 PM
Tad's Avatar
Tad
oh btw about the closed throttle voltage,
I have a feeling, not 100% sure,
but I think the true objective is to get the voltage as close to zero, without going too low.
which maybe why Xsi's car ran better at .32 rather than the manuals .45
Old Jul 6, 2004 | 09:46 AM
Spunkster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">
you can actually remove the tb and adjust it by measuring resistance through the tps.</TD></TR></TABLE>
You obviously can't adjust it at WOT....this is why you adjust it at idle, knowing it should be at .49V completely closed at idle, you can't make any other adjustments...if it is messed up beyond adjustment, then you need a new one.
Think before you post!
Old Jul 10, 2004 | 12:23 PM
what would happen if i ran my car without my tps?(what goes on if its not in?) will it hurt it?
Old Jul 10, 2004 | 03:41 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thinknology &raquo;</TD></TR><TR><TD CLASS="quote">what would happen if i ran my car without my tps?(what goes on if its not in?) will it hurt it? </TD></TR></TABLE>
hmm, never tried running it without the tps plugged in...
but considering how FUCKED it will be with the tps plugged in but not set correclty,
I doubt it'd even start.
who knows though, all depends on what the ecu does without the tps plugged..
maybe it has a default "ok but not great setting" i duno.
Old Jul 12, 2004 | 06:19 PM
Default Re: setting my tps (Tad)
alright i got my new tps in and set to .45 it runs pretty good but idles low like 600 -500 low and stalls occasionally when i stop it will stall and stalled once when i was goping down the road with the clutch in ....? ive heard others were set at .32 but mine will only go down to .44 so i figure .45 must be right and my idle screw wouldnt need to be adjusted would it jsut because i messed wiht the tps and its still throwin a cel how do i check what the code is? i thought i remembered but i must be doin somethin wrong cus im not gettin it
Old Jul 12, 2004 | 08:14 PM
Xsi's Avatar
Xsi
If your idle is steady but low just adjust the idle screw up the top of the TB until you get around 700-800 RPM
Old Jul 12, 2004 | 09:10 PM
Tad's Avatar
Tad
so you still get a tps code?
it could be the wiring, or the tps might neet replacing.
Old Jul 13, 2004 | 06:50 PM
Default Re: (Tad)
i just replaced it and it ildes steady like a said only stalled twice after put in the first day hasent done it since but still throwin a code .... how do i check to make sure its the tps code (pretty sure but ya never know i guess)
Old Jul 13, 2004 | 08:53 PM
Tad's Avatar
Tad
jump the service check connector,
turn ignition to ON
count the flashes,
long = 10, short = 1
so ____ _____ _ _ would be 22
tell us what you get.
Old Jul 13, 2004 | 09:52 PM
Sack Master's Avatar
Default Re: (Tad)
'91 CRX Si B16A w/LSD
Your ecu has a light that will flash the codes, but as stated before long dash = 10 short = 1. TPS will 7 short blinks.
Old Jul 14, 2004 | 06:51 AM
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">jump the service check connector,
what exactly do u mean by that???
Old Jul 14, 2004 | 07:44 AM
Tad's Avatar
Tad
what exactly do u mean by that???</TD></TR></TABLE>
hmm,
you should be able to find the CEL checking process in a search somewhere,
theres even a video of the process floating around.
anyone doing their own honda maintenence should know this.
look it up in a haynes or something, if you can get a helms that'd be better.
Old Jul 14, 2004 | 02:02 PM
Xsi's Avatar
Xsi
http://www.integra.orcon.net.nz/ecucodes
On my car I didn't need to jump the connector since it's a 1990, you will find a grey plug that appears to go nowhere located behind the passengers kickpanel. You need to join the wires by sticking a paper clip in the plug.
Also yours will be on the other sie since mine is JDM
Old Jul 15, 2004 | 05:04 PM
Default Re: (Xsi)
why would i need to jump two wires? i got the codes off of my ecu and one was the tps but i got another that is 15- ignition output signal so whats up with that my car still starts and everything??? but stalls very occasionally
Old Jul 17, 2004 | 12:52 PM
tt
Old Jul 17, 2004 | 03:22 PM
Xsi's Avatar
Xsi
Ok, you must have a gen 1 b16 so you don't need to jump the connector. Since you're still getting the tps code that must be causing your stalling. Have you reset the ECU?
