quick tech question
Old Jul 7, 2004 | 10:27 AM
spaceman's Avatar
Default quick tech question
whats up doods..i havnt started up my vehicle in a few months and i want to crank the motor without out it starting up so i can get some oil circulation...what wire/wires do i unplug??(its a b16,obd0)
Old Jul 7, 2004 | 11:09 AM
JimBlake's Avatar
Default Re: quick tech question (spaceman)
Take out the spark plugs so you don't get any compression.
Take out fuel pump fuse or unplug the injectors so you don't get fuel.
Old Jul 7, 2004 | 01:26 PM
murtnabila's Avatar
Default Re: quick tech question (JimBlake)
take out the ecu fuse, it's under the hood/passenger side
Old Jul 7, 2004 | 01:37 PM
murtnabila's Avatar
Default Re: quick tech question (murtnabila)
I would change the oil too if it has been sitting for a while.
Old Jul 7, 2004 | 03:45 PM
spaceman's Avatar
thanks doods,the oil is good and the head gasket is bad,hehe..i heard from somewhere that you can disconnect a plug that goes to the distributor and thats all you need to do..whats up with that? or should i go with what you guys said?
Old Jul 8, 2004 | 03:47 AM
JimBlake's Avatar
There's probably half a dozen ways to disable fuel & spark. Unplugging the distributor would probably do both, since the ECU won't fire the injectors if it's not getting a signal from the CYP & TDC sensors. Pulling the ECU fuse, too, & that's probably easiest.
Old Jul 8, 2004 | 09:03 AM
spaceman's Avatar
thanks jim
wtsapexipowerfc
Aug 21, 2011 12:05 PM
speedooo
Dec 17, 2007 09:22 PM
JDMB20TDA
Aug 22, 2007 11:37 AM
FuNkDrSpOt
14
Dec 11, 2006 06:40 AM
hmonglonertim
May 3, 2002 12:29 PM
