Installed VAFC and get code 22 at higher RPM's.... WTF?
Old Jul 6, 2004 | 10:17 PM
Ls1 FD3s's Avatar
Default Installed VAFC and get code 22 at higher RPM's.... WTF?
This has happened to my friend as well. Everything was kosher with my setup untill i installed the VAFC, now at high RPM's mainly in 3rd and sometimes 2nd, i get code 22 which is the VTEC oil pressure sensor. What gives? i know the VAFC is now wired in between the sensor and the ECU, is the ECU just throwing the code because it knows its not getting the proper signal? checked oil, all the basics, and everything was fine....?
Ran 100% flawless prior to installed the VAFC, yes it was done properly, and im left clueless...help!
-mods:
b18c, skunk2 mani, 4-1 header, kenji chipped OBD1 p28, CTR cams, underdrive pullies, ACT HD PP w/ 6 puck, shorty intake, intank 190 pump, custom 2.5 exhaust.
Old Jul 7, 2004 | 08:37 AM
Ls1 FD3s's Avatar
Default Re: Installed VAFC and get code 22 at higher RPM's.... WTF? (Ls1 FD3s)
anyone?
Old Jul 7, 2004 | 11:21 AM
Ls1 FD3s's Avatar
where the info at?
Old Jul 7, 2004 | 12:32 PM
Ls1 FD3s's Avatar
hello?
Old Jul 7, 2004 | 01:54 PM
tegon-gsr's Avatar
Search... vtec pressure switch or vafc hook up wrong "vtm" wire not cut or connected.
Old Jul 7, 2004 | 08:15 PM
Ls1 FD3s's Avatar
Default Re: Installed VAFC and get code 22 at higher RPM's.... WTF? (tegon-gsr)
my VTM isnt connected, this i know for sure.
i have a 94 del sol S and i followed the wiring diagram according to APexi to wire in the VTM wire, after i did this, can ran like *** and i got a CEL (code 3, the map sensor) stupid diagram licks ***. obviously the wire they specified for the VTM is the wrong one,,, just like how the TPS is the wrong one as well....
What is the proper pin for the VTM signal on a 94 del sol???
Old Jul 8, 2004 | 12:29 AM
TurboTeG4's Avatar
I had a vafc in my 94 gsr and it was giving me a code 3, for the longest time I didnt know why. I took out the vafc and wholla it was gone , i was running it a 0 settings etc. but now I got hondata s200b on its way
Oh and the code 3 puts the car in crap mode
Old Jul 8, 2004 | 12:33 AM
Ls1 FD3s's Avatar
Default Re: Installed VAFC and get code 22 at higher RPM's.... WTF? (TurboTeG4)
code 3 is map sensor,,, stupid Apexi says thats where you cut and wire in the VTM signal,,, WRONG! Trying to figure out where the VTM signal really is. Also apexi's diagram as to where the throttle signal should be is totally wrong as well...
Old Jul 8, 2004 | 06:10 PM
TurboTeG4's Avatar
You think even in my gsr I was actually tapping ino the map sensor wires?
Old Jul 8, 2004 | 07:10 PM
Ls1 FD3s's Avatar
yes,,, you car ran rough as **** and probably wouldnt idle,,, correct?
code 3 is the map sensor, after i reconnect it back to stock, the code went away and car ran like a champ..
Still throwing code 22 on high RPMs tho... stupid asses at apexi...
Old Jul 8, 2004 | 09:08 PM
TurboTeG4's Avatar
Oh i could idle and run it fine but it would somewhat flood the engine and bogs, but thats before I took out that crap
chulopilong
Mar 19, 2005 09:39 AM
97dc2
Sep 19, 2004 08:54 PM
PanamaVTI
May 31, 2004 03:09 PM
S2KP
Oct 8, 2003 07:08 AM
topsekret
Dec 22, 2002 05:49 PM
