Tap size for a B16A head bolt.
Old Jul 5, 2004 | 05:41 PM
ImAcracker's Avatar
Loved
Default Tap size for a B16A head bolt.
What size tap should I use to clean the head bolt hole for a B16A? I ran a 12x1.5 and now Im not so sure that it was the correct size. The bolt still fits snug if I thread it into the block though.
Old Jul 5, 2004 | 06:04 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: Tap size for a B16A head bolt. (ImAcracker)
i do belive 12 X 1.5 is correct, but let someone else back me up.. and then your 100%.
Old Jul 6, 2004 | 03:43 PM
ImAcracker's Avatar
Loved
^_^
Old Jul 7, 2004 | 11:23 AM
DonF's Avatar
Default Re: (ImAcracker)
Seeing as the threads are 11mm by 1.5 I bet you had some resistance when cleaning the threads, now all you need is a custom set of head bolts or studs made.
Old Jul 7, 2004 | 11:41 AM
ImAcracker's Avatar
Loved
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Seeing as the threads are 11mm by 1.5 I bet you had some resistance when cleaning the threads, now all you need is a custom set of head bolts or studs made.</TD></TR></TABLE>
Damn. So I used the wrong tap size then hu? This sux. I already purchased some ARP head studs. And I only ran the tap through one of the threads. I guess I will be heli coiling it then. Thanks for the responce.
Old Jul 7, 2004 | 01:55 PM
DonF's Avatar
Good news is you only did one, get it Timeserted instead of heli-coil, as they are not long enough.
Old Jul 7, 2004 | 02:00 PM
ImAcracker's Avatar
Loved
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Good news is you only did one, get it Timeserted instead of heli-coil, as they are not long enough. </TD></TR></TABLE>
Well Ive been doing some searching and supposedly they make longer Helicoils that will cover the whole thread of the bolt. Hopefully I can find them. Thanks.
oneprelude
Mar 20, 2010 01:14 AM
rich7777
Feb 19, 2010 06:23 AM
Andrew J
Apr 1, 2007 03:31 AM
m3bluegsr
Aug 28, 2004 12:54 PM
