Tranny Questions
Old Jul 3, 2004 | 05:17 PM
carblegal's Avatar
Default Tranny Questions
B18C tranny.
No grinds, Shifts are smooth. No problems, But when I drained the tranny fluid (approx. 10k miles since last change) there was metal shavings on my magnet drain bolt. Fluid was not dirty either.
What is wearing? Now occasionly I here some knocking sounds coming from the tranny (not very loud but noticable that something is wrong) Sometimes I can stop the sound when I step on the clutch pedal, slide it into gear and than back to neutral, release the pedal.
Old Jul 3, 2004 | 07:13 PM
bigTom's Avatar
Default Re: Tranny Questions (carblegal)
maybe t.o. bearing? just a guess... how big are the shavings? are they little shavings or more like chunks? also make sure u have enough oil in the tranny
Old Jul 3, 2004 | 09:17 PM
carblegal's Avatar
Default Re: Tranny Questions (ek9t)
I dont think it is the Throw Out bearing making the noise.
The noise is still present if (with shift lever in neutral) I just step on the clutch and release it while not touching the shift lever.
To make the noise go away (with shift lever in neutral):
1. step on the clutch pedal
2. move shift lever to any gear
3. move shift lever back to neutral
4. Release clutch pedal
When I opened the fill hole, Tranny fluid trickled so I was not low. Shavings were little. Tranny fluid was not dirty (It shouldnt; last change was only 10k miles ago)
the_dxB16
12
Dec 1, 2008 09:43 AM
amej8
Apr 7, 2008 04:14 PM
Jeff C
Jun 20, 2003 03:43 PM
member32
Feb 3, 2003 10:30 AM
