phantom grip lsd system
Old Jul 6, 2004 | 07:26 AM
one8toh8's Avatar
Default phantom grip lsd system
i am just wondering if any one has this lsd setup and if you have had any problems with it, meaning breakage or any other problems. the reason is because you can make your non lsd tranny lsd for only $300.
Old Jul 6, 2004 | 07:33 AM
devnull's Avatar
Phantom grip does not make a LSD. Phantom grip mearly make your tranny spit out power eqaully to both wheels, instead of having 80% to non traction wheel and 20% to the grippy one. And this is all the time. It doesn't change as conditions change.
Where as some "LSDs" will give power equally as need, but a real LSD will give power to the wheel with the most traction. These change as conditions change.
For the money the Phantom grips aren't bad. However if it was my money I would want to save up for a real LSD.
Old Jul 6, 2004 | 10:00 AM
Kendall's Avatar
You won't achieve near the performance upgrade from a Phantom Grip as you will from an OEM Honda LSD or something like a Quaife LSD. The only drawback to going with a real LSD is the price. Also note that either way you will have to pay someone to install it, unless you feel comfortable tearing apart a tranny.
Old Jul 6, 2004 | 01:11 PM
JDM_JON's Avatar
Default Re: (Kendall)
oem all the way...i have a gsr diff with a phantom grip installed for sale
Old Jul 6, 2004 | 03:24 PM
Mugen Hamster's Avatar
Default Re: (JDM_JON)
Just do a little searching about the product. From what I've read, it has a tendancy to not work all the time and also ruin trannys.
Old Jul 14, 2004 | 08:28 AM
ricky1969's Avatar
Default Re: phantom grip lsd system (one8toh8)
I drove a car that had one. It did not perform anywhere near as well as a Honda or Quaife unit would.
please_hop_off
Dec 20, 2009 04:11 AM
stock99si
May 13, 2007 03:44 PM
HondaPH22
Nov 23, 2006 12:52 AM
KustomCrx
Sep 29, 2004 10:17 AM
crj_lll
Dec 16, 2003 01:24 PM
