Forgot to add oil :-(
Old Nov 10, 2005 | 04:09 PM
doublejz's Avatar
Default Forgot to add oil :-(
Well as much as a dumbass as I am. I put 1 quart of oil in my fresh rebuild and got distracted. So I jump in a little later and fire her up. the oil pressure goes up to like 30 then goes to 0. So it idles for about 10 secs, im thinking its still purging the lines, then the oil light comes on and i shut her off. My question, do you think I will still be ok especially since everything was covered with assembly lube or should i rip it back down?
I got the flame suit on and ready for hell.....
Old Nov 10, 2005 | 04:24 PM
recap's Avatar
Default Re: Forgot to add oil :-( (doublejz)
Dont wont to lie to you an say its ok,but if you used good assembly lude and you put some what of oil in it i wouldnt worry too mutch. When you fill it with oil do you hear any knocking? If not,the assembly lube saved you. Did you replace any bearings on your rebuld cause that would ef be a plus....
Old Nov 10, 2005 | 04:25 PM
doublejz's Avatar
Default Re: Forgot to add oil :-( (recap)
everything was replaced...
Old Nov 10, 2005 | 04:32 PM
recap's Avatar
Dose it make any kind of rod knock with oil in it?
Old Nov 10, 2005 | 04:33 PM
doublejz's Avatar
dunno....maybe not really sure, I am waiting on a valve cover gasket so right now its just sitting on the head. couldn't tell where the noise was coming from
Old Nov 10, 2005 | 04:38 PM
recap's Avatar
is this a turbo set up
Old Nov 10, 2005 | 04:46 PM
doublejz's Avatar
no, its gonna be sprayed.... or im hoping. depending on what happens tomorrow when i get the valve cover gasket and take it out on the road
Old Nov 10, 2005 | 04:59 PM
mmuller's Avatar
Mad Scientist
drain the oil and look for metal
Old Nov 11, 2005 | 11:43 PM
D@nnY's Avatar
Default Re: Forgot to add oil :-( (mmuller)
it should be fine....put oil in it and verify you have the proper oil pressure...if you dont take it apart...
Old Nov 12, 2005 | 05:53 AM
doublejz's Avatar
Default Re: Forgot to add oil :-( (D@nnY)
well i took it for a ride last night, other then needing a valve adjustment done the correct way now.... it sounds alright
Old Nov 12, 2005 | 03:19 PM
gents97civ's Avatar
It'll be fine
Old Nov 12, 2005 | 03:26 PM
85's Avatar
85
Default Re: (gents97civ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gents97civ &raquo;</TD></TR><TR><TD CLASS="quote">It'll be fine</TD></TR></TABLE>
champLSinteg
Oct 3, 2007 07:04 AM
Serenity Now!
Jan 29, 2007 06:31 AM
djmatix
Feb 7, 2005 07:58 AM
CHRIS 1.8
Aug 28, 2003 06:01 AM
deepnite
Oct 9, 2002 01:46 PM
