Purchasing GSR block, dissassembled girdle????!?!?!
Old Nov 11, 2005 | 05:16 AM
JDM00SI's Avatar
Default Purchasing GSR block, dissassembled girdle????!?!?!
Sup,
I'm purchasing a GSR block. My buddy was telling me if the girdle has been dissassembled it is nearly impossible to put it on the right way into OEM Specs. My buddy told me if the girdle is dissassembled, im better off not using a girdle, because if it is put on wrong then it will mess something up. Well the block im about to purchase is dissassembled, and the girdle is also. The seller said you MUST remove the girdle in order to remove the crank shaft. Sorry for the stupid question but someone must help. Thanks
JDM00SI's Avatar
Default Re: Purchasing GSR block, dissassembled girdle????!?!?! (JDM00SI)
Is this a good idea? Do you really have to remove the girdle to remove a crankshaft?
Old Nov 11, 2005 | 06:00 AM
JDM00SI's Avatar
anyone?
Old Nov 11, 2005 | 06:17 AM
nasteboyii's Avatar
THE girdle covers the caps, which have to come off to take out crank
doesnt sound like your boy knows what the hell he is talking about
it goes block then crank then caps, then girlde then oil tray, then pick up then oil pan
all these things have to come off to get crank out
dan
Old Nov 11, 2005 | 06:43 AM
JDM00SI's Avatar
ah ok thanks alot for reply. i know this is the dumbest question,
mod please delete this thread.
drdisco69's Avatar
There are dowel pins that locate it, taking it out is not a big deal. It will go back in where it was just fine, your friend is talking out his ***.
hondamoney
Aug 6, 2010 07:17 AM
JDM90Sleeper
Jan 17, 2008 09:36 PM
GarageAlchemist
May 25, 2007 01:58 PM
eleet
May 19, 2007 05:52 PM
EK FLY
Apr 15, 2006 05:42 AM
