solid cel need uberdata help
Old Nov 14, 2005 | 04:00 PM
reddg3214's Avatar
Default solid cel need uberdata help
ok i got a turbo b16 wit a p28 ecu it was chipped before but i guess the chip was screwed cause it didnt throw no codes but the map was like 6 bars across and 4 bars down its a 27SF512 so i burnt a AT29c256 and put it in and got a solid cel it runs good and all but i need too figure out whats checked too throw a solid cel plz help out and let me know whats goin on...... ima post a pic of the misc ive checked too give a idea
PLZ POST Qs?As TOO HELP OUT IN ANY WAY
and no bull like my ecus bad i know its good cause i canuse the one chip and no codes
Old Nov 14, 2005 | 04:13 PM
reddg3214's Avatar
Default Re: solid cel need uberdata help (reddg3214)
Old Nov 14, 2005 | 04:38 PM
reddg3214's Avatar
help bump.................................
Old Nov 14, 2005 | 06:39 PM
reddg3214's Avatar
bored bump
Old Nov 14, 2005 | 07:16 PM
EnzoSpeed's Avatar
Misc. tab looks good to me. I don't think that's it.
It could be a hardware issue - like the chip wasn't at the right end of the burner, or a single leg on the chip could be bent down. Also, it might be a bad chip.
Old Nov 15, 2005 | 03:07 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: solid cel need uberdata help (EnzoSpeed)
If the program you burned is corrupt it will throw a solid CEL. Try it again.
Old Nov 15, 2005 | 11:12 AM
reddg3214's Avatar
Default Re: solid cel need uberdata help (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">If the program you burned is corrupt it will throw a solid CEL. Try it again.</TD></TR></TABLE>
hows it get corrupted?????????
Old Nov 15, 2005 | 03:52 PM
EnzoSpeed's Avatar
Because uploads/downloads fail sometimes. Try burning the chip again. If that doesn't work, a good second step would be to try another 29C chip in case the one you have is bad.
Are you using a Moates.net chip burner?
Old Nov 16, 2005 | 08:02 PM
reddg3214's Avatar
well i have another 29c it does the same but just makes it worse too where its redlinin at say 4k and also have a sst sf and it doesnt throw solid cel but still makes it run like crap the one that throws solid cel runs best of all though redlinin at 8500 and now i need too ajust the tables and itll run great but any ways i think the chipsmight be bad or somethin cause the sst chip was from phearable.net so idk there rep but who knows????????????????????????????????????????????? ???????
and its burn1 and a hulog from moates
Old Nov 17, 2005 | 03:33 PM
EnzoSpeed's Avatar
How are you burning new chips? Are you reading the data off of the chip you bought, and then burning it to a new 29c chip?
Because the data often corrupts when you read a chip and try to open the data in uber.
Old Nov 17, 2005 | 04:24 PM
2k.civic.si's Avatar
he says he copied from the chip he got to the new ones...so if the chip he copied from throws solid cel so will every chip he copies it to...
if you want send me your bin and ill send you back a working bin based on the bin you send me...was the bin your trying to use for your turbo tuned with a wideband?
Old Nov 19, 2005 | 03:28 PM
reddg3214's Avatar
well ive tried too open stock gsr and import p28 then set boost tables and crap then burn it wit the burn1 from comp too chip and also like yall said from chip too chip from chip wit out solid too chip that throws solid and like wise and no i havent got my wideband hooked up yet cause as of now was runnin straight pipe but will have it hooked soon and ill send a bin
Old Nov 20, 2005 | 12:12 AM
list out your setup and i can make u a base map
bigblue7t6
Engine Management and Tuning
Aug 31, 2012 02:42 PM
digitaldetox
Oct 5, 2010 07:23 PM
mortificationrock
11
Jan 17, 2008 02:08 PM
Vtec92Civic
Mar 30, 2005 11:54 AM
Vtec92Civic
Mar 29, 2005 11:16 AM
