Coolant leak
Old Nov 16, 2005 | 02:54 AM
Jeffrey9's Avatar
Default Coolant leak
I haven't had to opportunity to get under the car and look. But I can easily rule out that it isn't the radiator or any of the immediate hoses.
Any other things that could be leaking?
I just want to be prepared for tomorrow.
Old Nov 16, 2005 | 04:45 AM
NJIN BUILDR's Avatar
Default Re: Coolant leak (Jeffrey9)
Heater core,heater hoses?
Glenn
Old Nov 16, 2005 | 10:31 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Coolant leak (NJIN BUILDR)
Are you sure it's leaking? Do you see a puddle of coolant on the ground? Or are you losing coolant (i.e.: bad headgasket, etc)?
Where is it leaking? Inside the car? Outside the car?
It could be many things, and don't rule out the radiator leaking right away. Honda radiators are notorious for having their plastic endtanks crack. Sometimes it's hard to see the leak, but it's there. You'll see a little green (or whatever coolant you have) by the endtanks.
You could have a bad radiator cap, the heater core could be leaking (if there is coolant leaking inside the car). There are numerous coolant hoses routed through the engine bay/firewall. Any number of them could be leaking/loose, not just the main radiator ones.
ShadowDaisy82
11
Aug 7, 2015 10:34 PM
prodjay10
Honda Civic (2001 - 2005)
May 27, 2015 09:23 AM
raju687
Sep 16, 2011 05:42 PM
liquidx
Aug 27, 2010 10:55 AM
honda_coupe
Jan 24, 2006 03:10 PM
