Quick question about installing a ITR girdle on an LS bottom end??
Old Nov 8, 2005 | 11:13 AM
caspers_hatch's Avatar
Default Quick question about installing a ITR girdle on an LS bottom end??
Ok, i have a built LS bottom end. I want to re-use my itr windage tray and pick-up but i need the girdle for the oil pick up to properly bolt to.
That being said, how had is it to install the girdle on my LS crank caps. Would i have to replace the bearings or could i "sneak" it on there and just re-torque the main bolts?
Old Nov 8, 2005 | 01:42 PM
Default Re: Quick question about installing a ITR girdle on an LS bottom end?? (caspers_hatch)
Sometimes i wonder about myself.
Disregard first post
Old Nov 8, 2005 | 04:25 PM
Honda Bull's Avatar
You'll need ITR/GSR main caps I believe for the girdle to work. Can't use 3 of the 5 LS mains when doing this.
Old Nov 8, 2005 | 08:07 PM
j87w's Avatar
Default Re: Quick question about installing a ITR girdle on an LS bottom end?? (HondaBullSQ)
If I could find the article I could help you but there is an article floating around here that shows what all needs to be done and how to do it. Very detailed. Try searching for it or maybe someone else will know what im talking about.
Old Nov 8, 2005 | 08:17 PM
mmuller's Avatar
Mad Scientist
you can use the gsr caps and line hone after
or you can grind a little of the stock caps in order for the girdle to sit flush, install dowels it and line hone.
Old Nov 11, 2005 | 04:28 PM
dalepatters's Avatar
Default Re: Quick question about installing a ITR girdle on an LS bottom end?? (mmuller)
SCAMMER WHERE IS MY MONEY
Old Nov 14, 2005 | 09:37 AM
D-Rob's Avatar
Default Re: Quick question about installing a ITR girdle on an LS bottom end?? (dalepatters)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you can use the gsr caps and line hone after
or you can grind a little of the stock caps in order for the girdle to sit flush, install dowels it and line hone.</TD></TR></TABLE>
Align-honing may not be needed.
On my B18A block, I used the ITR main caps and girdle, and nothing needed align-honed. Wound up being perfect.
Old Nov 14, 2005 | 09:53 AM
mmuller's Avatar
Mad Scientist
Default Re: Quick question about installing a ITR girdle on an LS bottom end?? (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">Align-honing may not be needed.
On my B18A block, I used the ITR main caps and girdle, and nothing needed align-honed. Wound up being perfect.</TD></TR></TABLE>
you got lucky;how did you check out of round on the bore?
Old Nov 14, 2005 | 10:13 AM
D-Rob's Avatar
Had the machine shop check the roundness.
They said it was perfect.
egboy94
Feb 20, 2009 05:23 PM
JLefevers
Dec 10, 2006 08:12 PM
inFamousOneSix
May 1, 2003 03:36 AM
zCivic
Jan 23, 2003 07:52 AM
vbphreak
Nov 25, 2002 09:51 AM
