valve guides
Old Nov 8, 2005 | 07:51 PM
raiden571's Avatar
Default valve guides
i tore my head apart tonight and the only thing left are the valve guides. they looked very scored up and one is looking kinda oval. how much can i expect a shop to charge for removal and installation of new guides? the reason being im putting all new valve train in and want everything inside to be new. thanx in advance
Old Nov 8, 2005 | 08:07 PM
supra8588's Avatar
they pretty much just pop on and off with the valves out you can do it i have done it many times just pop off the little spring and your in business
Old Nov 8, 2005 | 08:32 PM
mmuller's Avatar
Mad Scientist
Default Re: valve guides (raiden571)
just have the same shop thas doing your valve job.
Old Nov 8, 2005 | 08:42 PM
xyrth's Avatar
Default Re: valve guides (mmuller)
my shop charges about $75 a side, but yah -- teh shop doing your valve job should be able to take care of it.
Old Nov 9, 2005 | 08:06 AM
raiden571's Avatar
Default Re: valve guides (xyrth)
what do u mean by a valve job. im going to use be using stock sied valves. a shop quoted me 50 bux for the whole thing, but im getting it for a deal with my bore/hone/resurface/etc.
this is what im going with http://www.honda-performance.com/valve-train.asp and http://www.honda-performance.c...d=372
Old Nov 9, 2005 | 11:56 AM
xyrth's Avatar
if you're replacing valves, you need a valve job. if you're putting the same valves back in the head, and keep them in the same spot, you should at least lap them to make sure you've got good contact.
Old Nov 9, 2005 | 12:18 PM
simike's Avatar
A valve job ensures your valves seal against the seat. It should cost $150-$200 for a 3 angle 16valve 4 cylinder head. Supra8588 was refering to valve seals I think??? Of course you know they need replacing. $75 per side for valve guides sounds about right. Let the shop remove and install the guides. Have any other plans for the head? Resuraced, pressure checked, valve stem height, ported..... Good luck with the build.
Old Nov 9, 2005 | 04:45 PM
raiden571's Avatar
those valve guides are 75 for the whole set. ill have to call the guy doing the guides and see how much he wants for the valve job as well. i dont have the money to go all out on this head. maybe when i have the money ill have it port and polished. but im just gonna put in stock sized valves, tit. retainers, new seals, and dual valve springs.hopefully the valvejob isnt to expensive, i aint no balla
KoRE
Apr 13, 2010 09:40 PM
seelyd
Dec 27, 2006 03:06 AM
djnikko
Nov 17, 2006 06:05 AM
VSBB6
Sep 11, 2005 11:07 AM
MysticAzn03
Feb 3, 2003 06:21 PM
