Valves, springs, and retainers
When is it needed to replace all three? Changing my botttom end and was wondering if i should change my valves, springs and retainers again. about 15k on them, crower valve springs and retainers, oem valves. what do you think?
what kinda pistons you running?
are there any problems with the current valve train?
are you going for reliability or speed or both hopefully?
lastly if you do upgrade your valve train replace the valve seals as well
If you only have 15k on the valve train and there are no problems with it then leave it alone, but if you got after market pistons and wanna make some power then get some supertech vavle train with aftermarket cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteNess »</TD></TR><TR><TD CLASS="quote">
If you only have 15k on the valve train and there are no problems with it then leave it alone, but if you got after market pistons and wanna make some power then get some supertech vavle train with aftermarket cams.</TD></TR></TABLE>
usdm itr pistons. No problems with current valvetrain. going for reliability. Yes i know i am going to replace the valve seals, that's why i ask this question.
