Losing coolant
Old Nov 13, 2005 | 12:02 PM
Bunta eg6's Avatar
Default Losing coolant
Drive a d16Y7 Boosted EG hatch and it is losing coolant. I cant find any leaks on hoses and car seems to be running fine. No air in the system. I am thinking a cracked headgasket and the coolant is just slowly burning off. But i lose a fair amount after a long drive around for a day. I think if it was a headgasket i would notice major overheating issues and white smoke coming out. But i cant see any of this? Leaky rad or what? Any help would be great. It just started this a week or two ago.
Old Nov 13, 2005 | 12:31 PM
zman's Avatar
Default Re: Losing coolant (Bunta eg6)
check the carpet on the floor of the car. I had the same problem and it was leaking into my car through the heater core. Hope this isn't the case with you though.
Old Nov 13, 2005 | 02:11 PM
dornon13's Avatar
Default Re: Losing coolant (zman)
have you checked the oil for coolant? or the coolant for oil? also try doing a leakdown test with the radiator cap off see if it pushes the coolant out. that will tell you for sure if it is the headgasket....im having a coolant issue too im blowin it out the overflow im hoping its the rad cap if not i guess ill be changing the HG
Modified by dornon13 at 11:27 PM 11/13/2005
Barmaleyka
Acura TL, RL & ZDX
Jun 3, 2017 11:15 PM
redm3turbo
Mar 26, 2013 03:09 PM
732xghost
Dec 22, 2006 07:22 AM
korean_teg
Sep 29, 2005 07:00 PM
94gsr18kid
Dec 29, 2004 08:12 AM
