Valve ?
Old Nov 12, 2005 | 09:22 AM
IntegraXSi's Avatar
Default Valve ?
Ok trying to do a valve adj. I cant get any valve lash I have the rockers as loose as they go and Still no lash... B18A Head with Crower 62402T Cams Duel VS and Ti Ret. And I think there REV valves but rev web site dosent show a B18A valve.. Could I maybe have the wrong Valve are b18c ones longer? Any help thanks
Old Nov 13, 2005 | 06:16 AM
IntegraXSi's Avatar
Default Re: Valve ? (IntegraXSi)
bump
Old Nov 13, 2005 | 10:47 AM
IN VTEC's Avatar
Maybe you're not on the base circle.
Old Nov 13, 2005 | 04:21 PM
NJIN BUILDR's Avatar
The B18a,b and the B18c are completely different valves (head dia. and stem dia.).Its more likely the valves were sunk in the heads to far from the valve job.You maybe able to have the tips surfaced back to stock height if they weren't sunk to far.It may be as simple as "IN VTEC" said and you may not be on the base of the cam.
Glenn
Old Nov 13, 2005 | 05:18 PM
IntegraXSi's Avatar
Default Re: Valve ? (NJIN BUILDR)
Well when I try to turn it over the Cams Bind up... I have #1 at TDC cant get them to turn an 8th of an inch before they bind
narfdanarf
19
Nov 3, 2010 10:07 PM
no2psi
11
Dec 20, 2006 05:46 AM
Tad
20
Aug 26, 2004 04:31 PM
turbopanda
Oct 6, 2002 09:00 AM
